Clutch Problem
Old Dec 28, 2006 | 01:49 PM
Tim 97Z's Avatar
Clutch Problem
My 97 with a McLoed Street Twin has been in storage for about 4 months. When I went to start it, ther was no clutch pressure at all. The clutch will not disengage and the pedal is completely limp.
Any suggestions?
Thanks
Tim
Old Dec 28, 2006 | 02:39 PM
97Camaro007's Avatar
Slave/Master Cylinder is what I would check first. Does it have fluid? Also see if your pedal is still hooked to the cylinder under the steering wheel.
Old Dec 28, 2006 | 04:46 PM
Bandit 1's Avatar
did it leak any fluid? sounds like it developed some air in the system.
Old Dec 28, 2006 | 06:00 PM
Tim 97Z's Avatar
Nope no signs of leakage.
Thanks
Old Dec 29, 2006 | 04:34 AM
Tim 97Z's Avatar
tttttt
Old Dec 29, 2006 | 08:07 AM
It's going to be something to do with your Slave/Master cylinder. It's what creates the pressure on your pedal. If your pedal has no pressure it has to be faulty or disconnected. Make sure it's connected properly on both ends and if it is.. then it would be the first thing I replaced. You can buy just the end but I would suggest buying the whole unit from GM. If you buy just the end you will have to deal with bleeding the cylinder and it can be a pain to get right.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
