looking for a new d/s
Old Dec 26, 2006 | 10:10 PM
gbu27's Avatar
i looked around and couldnt find alot on driveshafts. As of now my car has the stock d/s. Are there any good aftermarket d/s that anyone can suggest? also wondered if it would cut some weight. One other thing i wanted to ask about was eng and tranny mounts, i know the engine has 2 mounts, but does the tranny have 1 or 2 and how hard would it be to change all of them out. Figured if not to hard i can do it when i get home, im building up a stockpile of parts while im over here in iraq and get to go home SOON for R&R.
Old Dec 26, 2006 | 10:13 PM
OBE1 95Z28's Avatar
The tranny has one mount on the tail; easy to change. The motor mounts aren't a high failure item; not sure if you need to change them.
From your mods, it looks like you're into drag racing. A lighter aluminum D/S will be a weak link when you get to higher HP levels. I'd stay with your stock steel one for now unless you have vibrations issues with it (common problem). The buy a better steel D/S from a shop like Denny's.
DropinDaTop91rs
Jun 19, 2008 08:25 AM
thesource2004
Aug 28, 2007 08:10 PM
Z95m6
Sep 30, 2004 10:51 AM
Z95m6
Sep 29, 2004 05:47 PM
