Koni Install on LT1 ?
Old Dec 25, 2006 | 10:21 AM
mfb_lt1birdman's Avatar
In the middle of installing my christmas present. Rears in no problem. Passenger side in no problem. But drivers side im stuck. For an LT1 w/o the soft brake lines from the master cylinder how the heck do you get to the torx bolt under the master? I tried loosening the master and pusing it out the way, but even with extension and a wobble attachment I cant get at it.
Old Dec 25, 2006 | 11:16 AM
OBE1 95Z28's Avatar
The master cylinder unbolts from the vacuum reservoir with a deep 15 mm; pull it off taking care not to kink the brake lines.
Old Dec 25, 2006 | 12:08 PM
I took the 2 15mm nuts attaching the master off. Are you saying you can pull it off with the lines attached? I tried loosen the damn flare nuts with no success. I do have a flare wrench and tried heat.
Old Dec 25, 2006 | 01:13 PM
SC/TA's Avatar
Yes, you can move it with the lines still connected. Its not hard to do. Just be careful with the lines. Let us know how you like the Konis. I have been thinking about getting some also.
Old Dec 25, 2006 | 01:18 PM
OBE1 95Z28's Avatar
Shoebox has a photo with the master cylinder moved with the lines still attached:
http://shbox.com/1/master_cyl.jpg
Old Dec 25, 2006 | 02:23 PM
SUCCESS! Too easy but im just reluctant to force stuff. I will let you know how they are. Im doing c5 brakes at the same time. Cant wait till a test drive. Now my only obstacle is changing the damn front brake lines. Those flare fittings wont budge.
Old Dec 26, 2006 | 09:15 PM
OBE1 95Z28's Avatar
Sometimes slightly tightening the fittings before loosening works to break them free.
Old Dec 26, 2006 | 10:48 PM
mitchntx's Avatar
Put the TORX heads in the passenger side and the hex head back in the driver's side.
Next time, you can get a wrench on the HEX without taking the MC loose.
Old Dec 27, 2006 | 10:34 AM
NJLT1SS's Avatar
As far as the Koni's go, you will love them. I went fron KYB's to the Koni's, and couldnt be happier. The ride is way better, and handles awesome too.
Nick
Old Dec 28, 2006 | 03:08 PM
Ultra_Dog's Avatar
My SS has Bilsteins, but my old favorite is Koni. I had Konis on my BMW and they were outstanding. The B's are good too, and it's difficult to gauge the differences, but it seems the Konis were a little stiffer and have some tight rebound.
HectorM52
Jun 23, 2016 08:42 PM
edman
Jan 22, 2015 02:45 PM
Jason Short
Jan 19, 2015 06:34 PM
Fedesna
Nov 23, 2014 11:06 AM
