Power Gains with higher Octane Levels?
Old Dec 24, 2006 | 12:36 PM
94_camm's Avatar
What are the power gains with using higher octane?
Old Dec 24, 2006 | 02:28 PM
2000GTP's Avatar
Using higher octane gas will not automatically add extra power to your car. If your car requires a higher octane then what you are using, it is most likely costing you power. By using the correct octane rating, you are simply recouping whatever you are normally losing.
Old Dec 24, 2006 | 02:40 PM
Octane has nothing to do with power, unless it enables you to run the engine with a combonation of timing and A/F ratio that produces more power. A stock CR engine is not going to see more power with very high octane fuels. Anything over 93-octane (at sea level) is overkill. And, octane requirement is reduced with increasing elevation (that's why they don't pump 93 in Denver), colder intake air temperatures, colder coolant temperatures, richer A/F ratios, higher humidity, etc.
Octane has nothing to do with energy content or burn speed. Its simply a measure of how well the fuel resists knock (detonation) and ping (pre-ignition).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
XtremeLt1
Sep 13, 2002 08:50 PM
