10.40mm wires?
Old Dec 12, 2006 | 03:56 PM
reamo04's Avatar
10.40mm wires?
well guys, i need new wires for my camaro and have always heard good things about taylor wires
i can get some 10.40MM wires, should i go ahead and get them? or should i stick to 8.5MM? My friend said the 10.40MM will work fine
Old Dec 12, 2006 | 04:00 PM
2000GTP's Avatar
It won't make a difference which size you go with. The 8mm's will be alot easier to get into the stock looms though. As for the Taylor brand, I have used them and have had no complaints, they are a good wire set.
Old Dec 12, 2006 | 04:03 PM
reamo04's Avatar
ah, ok. thanks a lot, just finally getting my car back tonight from being looked over (its been down for a week and actin funny)
found out that in 1 day i had 6 plugs crap out all at once, and burnt 2 wires which would explain why it was actin funny
now im going NGK tr-55s and 10.40 MM wires
2000gtp, i <3 u man, u always know the answer to my question *bows down to you and kisses your foot*
Old Dec 12, 2006 | 05:31 PM
FuryZ28's Avatar
Yeah, I think for the most part, the larger diameter wires are nothing more than 8mm wires, with thicker insulation...
Old Dec 17, 2006 | 07:54 PM
rskrause's Avatar
They will be bitch to route and you won't gain a thing.
Rich
Old Dec 17, 2006 | 08:34 PM
byrons1502's Avatar
run the taylor 8mm and save you some headaches, the 10.4 mm gain nothing but headache
Old Dec 26, 2006 | 10:09 PM
OBE1 95Z28's Avatar
I've used both the Accel 9000 and the MSD 8.5's; I prefer the Accel's. They're 8mm and will fit in the stock location.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
