3.5 inch exhaust, Fit over the Axle??
Old Nov 27, 2006 | 04:49 PM
T/A KID's Avatar
Guys I am posting this here since I don't think anyone will see it over at the exhaust section.
Will a 3.5 inch madrel bent tube go over the axle and clear the Factory panhard Bar.
Doing a 3.5 inch exhaust and I need to know if I will run into problems??
Plus does anyone know who has the best deals on 3.5 inch 90 degree elbows???
Thanks
Old Nov 27, 2006 | 04:50 PM
PLEASE post in the correct section.
Moving......
Old Nov 27, 2006 | 05:00 PM
2QUIK6's Avatar
If the pipe will fit over the stock panhard bar, it will bang around on it over bumps.
You need to minimally get a relocated bar like this one from BMR.
These are twin 2.5" pipes and you can see the most area is near the outside pass side, there's about 1" under it and about 1/2" above it.
Old Nov 27, 2006 | 05:17 PM
T/A KID's Avatar
I looked at the BMR setup since I have 2.5 True duels on the car right now. just thought it woulbe be more simple to do a 3.5 single.
So a Single 3.5 won't fit?
Old Nov 27, 2006 | 05:19 PM
Fbodyboy1994's Avatar
i think it will,b/c mufflex sells catbacks up to 4 inches and they say nothing about having to relocate the panhard rod or anything like that
Old Nov 28, 2006 | 09:59 AM
A 4" single will fit, but its a "tight" fit - this is the Mufflex 4":
Old Nov 28, 2006 | 11:04 AM
Schweet97Z's Avatar
2 2.5 inch pipe will flow better than a single 3.5 inch pipe wont they? so y would you switch back to a single pipe? ground clearance issues or something?
Old Nov 28, 2006 | 01:32 PM
teke184's Avatar
the pipes themselves will not neccesarily flow better.
without getting into the dynamics of fluid (in this case air/exhaust) flow through a pipe.....here are some calculations:
cross sectional areas:
2.5" pipe = 4.91 sq in
3" pipe = 7.07 sq in
which represents a 30% increase in area
3.5" pipe = 9.62 sq in
dual 2.5" pipe = 9.82 sq in
which is a measly 2% increase
4" pipe = 12.57 sq in
dual 3" pipe = 14.14 sq in
which is a 11% increase
realize that the addition of 2 mufflers in place of one, will probably flow better, even if they are the same kind. but the pipes themselves are not much different.
Old Nov 28, 2006 | 06:38 PM
T/A KID's Avatar
Thank you so much for the pic Fred, gives me something to go by been collecting pics all week.
teke184 I know that 2.5 duels is pretty much equal to a 3.5 single but the duels get on my nerves in a few ways.
1. Sets to low to the ground, and I think it looks a little tacky having two exhaust mufflers cut at the axle hanging down, plus it drags when I am not careful.
2. The exhaust is too loud with the Bullets, and dumps at the axle's and makes everyday driving seem a little uncomfortable specially when I have people of the opposite gender riding with me , lol
3. I have it set up where I would have to cut the exhaust to get it out of the way, seems to hard to get to the tranny, TQ arm, Driveshaft, ETC
Don't get me Wrong duels are nice but not for me, lol
The new setup will be 3.5 madrel bent into a magnaflow muffler (Quiet but yet people have ran 700RWHP ane lost 5 hp from taking it off with a similiar camshaft and setup to what I have). I do plan to set this exhaust up similiar to the Borla with an adjustable plate setup near the muffler (just like the borla) so I can adjust the sound of the exhaust note if I chose to.
Old Jan 13, 2007 | 10:03 PM
metallicsniper's Avatar
properly bent tubing should fit at 3 1/2 but that would be a custom job and if you hit a bump you better believe that the axel tube is going to hit the pipe
Old Jan 14, 2007 | 11:06 PM
Mufflex makes both 4" and 3.5" mandrel-bent intermediate pipes for the 3rd and 4th Gen cars. The axle tube is nowhere near the pipe.
Old Jan 16, 2007 | 10:04 AM
mzgp5x's Avatar
I did a Mufflex 3 1/2 conversion. It fits over the axel and thru the pan-hard bar/ body access. I did not like their clamping hardware and designed/ welded my own with 3/8 fasteners. So far, I have no issues with pipe/ body contact.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
