Old 11-26-2006, 10:56 AM   #1
MARKTHOMASBRAND
What Octane Rating Do You Guys in The U.S Have?
Hi,
Just wondering what the octane rating is in the U.S of your unleaded fuel.
In the U.K regular unleaded is 95 Octane and super-unleaded is 97 Octane.
All the best,Mark.
__________________
Sebring Silver '95 Z28 M6,EBC slotted front rotors & red-stuff ceramic pads,Magnaflow stainless y-pipe and cat,Pypes SGF55 3" cat-back exhaust with 3.5" stainless tips,MSD blaster coil,MSD 8.5mm wires,CRT alloy intake elbow & Air foil,UMI performance strut brace,skip-shift eliminator,clear corners,leather,T-tops.68,XXX miles.
MARKTHOMASBRAND is offline   Reply With Quote
Old 11-26-2006, 11:50 AM   #2
2000GTP
Premium Member
2000GTP's Avatar
91 and 93 is the premium grade around here.
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
2000GTP is offline   Reply With Quote
Old 11-26-2006, 11:59 AM   #3
Injuneer
Super Moderator
You can't compare the pump posted octane number in the US to those posted in Europe. Europe uses a different octane rating for posting on its pumps, compared to the US. Europe posts "research" octane. US posts the average of "research" and "motor" octane..... or (R+M)/2
Research octane is a measure of the fuel's ability to resist detonation, as measured through a test routine that most closely simulates "normal" driving... part load operation. Motor octane is measured using a a test routine that more closely resembles high load operation, or what you get when you push the engine to max load/WOT. Research octane can be anywhere from 5 to 10 octane numbers less than Motor octane.
Octane requirement is also heavily affected by altitude, so you may find US fuels rated at 93-octane (R+M)/2 as sea level, and fuels rated at less than 90-octane in Denver, where the altitude precludes the necessity of any higher octane.
Good reference on gasoline:
http://www.faqs.org/faqs/autos/gasoline-faq/part1/
__________________
Fred
94 Formula A3+1: 381/TH400+OD/N2O 11.1 @ 128 on a 125-shot
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Injuneer is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
