Aluminum heads with headers...
Old Nov 23, 2006 | 10:53 PM
shock6906's Avatar
This question is for the guys with aluminum heads that put headers on their cars. As you may or may not know, I've been looking for Breslin bolts for my headers but have since given up the search. I want to know what kind of bolts you aluminum head guys are using for your headers. Have you had any problem with them backing out? I've seen posts that say the aluminum heads are more prone to heat expansion than the iron heads, that's why I ask. Also, how many times did you have to retorque them after the initial install and how often did you check them? Thanks for your help guys.
Old Nov 24, 2006 | 11:57 AM
2000GTP's Avatar
I used the bolts that came with the Pacesetter headers, they haven't backed out once ever since they have been on the car. Others have been less fortunate, such as my friend for example, whose bolts backed out so much that he ended up trashing both of his header gaskets. From what I have heard, Breslin is no longer in business. Stage 8, however, makes a locking header bolt kit and are sold through a few of the supporting vendors on this site.
Old Nov 24, 2006 | 10:04 PM
shock6906's Avatar
Thanks for the input. I know about the stage 8 header bolts, I may end up going with them. I'd like to hear a few other people's experiences first before I make my final decision.
Old Nov 28, 2006 | 04:08 PM
RedRyder518's Avatar
Why isn't Breslin no longer in business? I used their locking header bolts on my car and I havn't had a problem with any of them backing out. I've had my AS&M headers for a year and a half and only retightened them once just to make sure. Even then, they didn't need it.
Old Nov 28, 2006 | 04:48 PM
2000GTP's Avatar
Someone mentioned in another post that the owner passed away.
Old Nov 29, 2006 | 12:58 PM
CamaroBoy96Z28's Avatar
ARP 1-in underhead length 12-pts. No problems in almost 4 years.
*Emilia*
May 13, 2015 09:05 AM
cmyname1
Feb 19, 2015 08:38 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
