Highest compression you guys have obtained with pump gas?
Old Nov 22, 2006 | 05:55 PM
bombebomb's Avatar
I went to a speedshop today, and told the guy I wanted to know how much a 550 hp motor would cost. He said I sappose you want to drive this on the street, I said yes, and he said it was possible/but its not. He said I would need a 12.5:1 ratio to get it, and pump gas cannot power a motor over 10:1 compression. I know our cars alone have higher compression and run off pump gas. So I was curious how high have you guys got it to?
Old Nov 22, 2006 | 07:54 PM
magnumv8's Avatar
Im running 11.5:1 on my 383 with 93 octane, and I know others on here are running higher than that...
Old Nov 22, 2006 | 08:20 PM
Dave89IROC's Avatar
its all in the dynamic compression, not static
Old Nov 23, 2006 | 10:08 PM
flatlander757's Avatar
How many cubic inches are you talking about? 350? 400+?
Old Nov 24, 2006 | 06:35 AM
Projectz28's Avatar
Putting mine together now. Its 12.4 static and I plan to run on pump gas. 93+ obviously but on regular pump gas.
Old Nov 24, 2006 | 08:17 AM
383Z4ME's Avatar
http://members.uia.net/pkelley2/DynamicCR.htmlThis is a really good response to your question and a calculator to find DCR
Old Nov 24, 2006 | 10:35 AM
myslowcamaro's Avatar
when i had the h/c installed, i was told the math comes down to almost 13:1. i run 94+ octane. (im not backing this claim up, just relaying, seems high to me too) they used a very thin head gasket set, 5.3 heads
Old Nov 24, 2006 | 10:53 AM
89TramsAmGTA's Avatar
Pump gas is a little vague. I can go to certain gas stations in my area an pump in 100 octane gasoline. Cost is $6.00 a gallon. Right along side are pumps for 87, 89 and 91 octane.
Old Nov 25, 2006 | 03:36 PM
bombebomb's Avatar
92/93/94 pump gas, sorry for being so vague.
Checking out that link
Old Nov 25, 2006 | 08:32 PM
ulakovic22's Avatar
I run 11.3 static and 8.9 dynamic. Typically 9.0 dynamic is accepted as the limit among most, but depending on squish and quench you could probably waver a little either way.
Deadbolt24
Jan 19, 2015 01:29 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
Red97LT1
Aug 7, 2002 05:45 PM
dmaastr
9
Jul 1, 2002 02:22 PM
