iron block 6.0 swap
Old Nov 20, 2006 | 11:31 AM
NORALTA's Avatar
iron block 6.0 swap
How much of a bitch is it to swap in a 6.0 out of a truck into a 98 TA. I would like to do this and add ls6 intake, cam it, and ported ls6 heads. Any major problems or concerns here?
Those of you that have done a 6.0 block swap please chime in.
Thanks
Old Nov 20, 2006 | 11:47 AM
davidarel's Avatar
The block is the same as far as bolts and dimensions. Everything from the ls1 will go onto the 6.0L.
Old Nov 20, 2006 | 01:16 PM
teke184's Avatar
you wouldn't really gain much over the LS1 block. a few more cubes is about it.
conversely you'll be adding 100lbs to the front of your car.
if you want more cubes you're better off going with a decent stroker short block. a nice aluminum block 382ci would work nicely with a fat 24x cam and ported heads
Old Nov 21, 2006 | 09:14 AM
AL SS590 M6's Avatar
It'll work but the extra weight isn't worth it unless you plan on abusing it later on with a ton of spray of FI.
Old Nov 21, 2006 | 09:40 AM
v-8's Avatar
v-8
Like stated there isnt that much of a point, i did it in my 99 b/c the ls1 threw a rod and i got a good price on the 6.0, everything on your ls1 will swap over, you do need to drill one hole for an alternator bolt, i would recommend using higher compression heads on it, the stock lq4's were only 9.5:1 and the lq9 were 10:1.
Pm me if you need some answers to your questions.
Old Nov 23, 2006 | 08:44 PM
Kyle@CSS's Avatar
Change the intake, oil pan, and drill the hole for the alternator. We have done many of these swaps at the shop.
Old Nov 24, 2006 | 08:32 AM
Kraest's Avatar
Retired
Yeah, I agree.
You're going from 346 to 364 cubes. Not a huge leap, however, when (if) you do a stroker motor, that's when the fun will really begin
Victor Lamb
Aug 26, 2017 02:52 PM
pimpss96
Feb 12, 2015 01:28 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Pro Stock John
Aug 1, 2002 09:18 AM
