Transmission trouble
Old Nov 17, 2006 | 01:18 PM
madmatt6988's Avatar
About a month ago my transmission stopped shifting. Its a 4L60E. I took it to a shop and they said it was two solenoids and after replacing them it worked fine. Then last night I'm driving and when I go to stop the trans makes a loud clunking noise and grinds when I take off. It isn't a real loud grinding sound but enough to know its a problem. Any one know what this might be? It gets louder the faster you go and it doesn't matter what gear though the higher gears don't seem as bad. I don't have the cash to get my tranny rebuilt. Anyone know what that might cost?
Old Nov 18, 2006 | 08:20 PM
Performabuilt's Avatar
Supporting Vendor
sounds like you may have a mechanical failiure in process , Personally rather than have it rebuilt locally I would look at a performance replacement trans generally they ened up being no more expensive than local and you get a better unit and warranty ,
Old Nov 19, 2006 | 09:02 AM
12SCNDZ's Avatar
This sounds like planetary failure. You can get a visual yourself by dropping the pan. If it's a planetary, you'll see alot of metal in the pan.
The cost all depends on how you want it built. Our 4L60E builds start at $700 and run up to $1400 for our "Pro Race" transmission. Unfortunately, our web page is down now for some reason.
Where are you located? You can give me a call at 302-250-1202, if you'd like to discuss it.
http://www.geocities.com/cahallperfo...l60ebuild.html
Thanks,
Frank
CPT
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
themex2002
Sep 2, 2015 03:47 PM
Schul365
Aug 22, 2015 10:00 AM
surreybrad
Jul 5, 2015 10:36 PM
