New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
U think i will pass MA emissions?
Old Nov 14, 2006 | 08:33 PM
CamaroRacing12's Avatar
U think i will pass MA emissions.....
i am planning on doing emissions friendly longtubes with dual cutouts right after the collectors....then true duals that dump at the axle..... no cats.... will i pass??
Old Nov 14, 2006 | 09:32 PM
jgeorger's Avatar
I think it would be really hard to pass the treadmill test with no cats. I'm not aware of anyone doing it.
Old Nov 14, 2006 | 09:51 PM
wat about if i put 2 high flow cats right after the collectors instead of the cutouts?.... o yea is dumping at the axle legal in MA?
Old Nov 15, 2006 | 09:01 AM
DWL-Z28's Avatar
googdluck on that one tony haha i heard MA emmisions were hard to pass
Old Nov 15, 2006 | 11:30 AM
Joe Crehan's Avatar
Per MA law, I believe exhaust pipes must exit at the stock location. Some shops are more **** than others as far as that type of thing goes. Ask around for a "friendly" inspection station. If you ask around the CZ28 Board, do everyone a favor and keep the shop's actual name and location limited to PM's. Also, be sure of who you are sharing this info with. Gotta protect the guilty ya know
I say your best bet is to keep with a CARB approved set up and use electric cut outs at the place of your choosing. That way you get the best of both worlds. Might be a bit more costly but it beats being flagged as failing emits and/or being cited on the street later.
The only other way is to have 2 different tunes available for your PCM. 1 tune for inspection time and the other for as soon as you leave with your sticker. This type of tune can be programmed to pass emits, even without cats. Again, it may be costly but....
Good luck with whatever you choose to do
Old Nov 15, 2006 | 02:21 PM
thx.... i kno a guy hes friendly....i think im gonna slap on 2 hi flow cats for inspection time and see what happens
Old Nov 15, 2006 | 04:23 PM
jgeorger's Avatar
Do you think he can pass the treadmill with no cats with just a tune? I know guys have done it with the old idle test, but the treadmill is a lot harder. I barely passed the treadmill with a pretty radical tune (halved my timing in the relevant areas) but I did have heads and a small cam (in my sig). This was back before the 96+ moved on to the OBD2 test. Perhaps the allowable emissions levels are different for 95 & 96?
Old Nov 15, 2006 | 09:00 PM
i dn...im gonna go without a tune...with 2 high flow cats...and hope for the best...this guy is foreign...and my dad shoots the **** with him every time he goes down there..... hopefully he lets me pass....this past year he gave me a sticker without even having my registration on me
Old Nov 16, 2006 | 10:27 AM
Joe Crehan's Avatar
it's all about clean combustion. As long as they mess with the fuel parameters and whatever throughout the RPM band of the testing range he should be fine. My buddy is an ASE Master Tech. He agrees.
Old Nov 16, 2006 | 12:38 PM
RealQuick's Avatar
Heck I'd fail ya for making me get on my stomach to hook the exhaust up for the treadmill test
Old Nov 16, 2006 | 01:56 PM
please explain it to me like a baby lol
Old Nov 16, 2006 | 01:57 PM
haha yea some guys prolly would
Old Nov 16, 2006 | 04:15 PM
Joe Crehan's Avatar
Oh shtop it...he assed
Old Nov 16, 2006 | 04:19 PM
jgeorger's Avatar
It's a balancing act between HC and NOx and I'm not sure you can do it without cats. If you lock the car in open loop and lean it out, HC will drop. However that causes combustion temps to rise and thus NOx wil rise as well.
All cams have an overlap period between the intake and the exhaust valves while both are open. Therefore no matter how perfect your combustion is, you will always been getting some HC's right from the intake out the exhaust.
Old Nov 16, 2006 | 08:53 PM
hmmm so just some dual cats should be ok?
