1993 Idle issues
Old Oct 14, 2006 | 07:11 AM
Honda Hunter's Avatar
1993 Idle issues
Will not having the AIT wire hooked to the sensor cause idle problems? Also I have longtube headers installed but no cat back. I cant install the O2 sensors until I get it to a exhaust shop. Will not having the O2 sensors connected cause idling problems? Right now the idle jumps from 1k to 1500. I think I have this issue just about nipped but I want to be sure.
Old Oct 14, 2006 | 10:44 AM
Re: 1993 Idle issues
Th IAT sensor is critical to the speed-density system. Without the temperature, the ECM can't do the "density" part of the air/fuel calculation. The ECM could correct for errors in the A/F calculation, but not without the O2 sensors hooked up. Likely to cause an idle problem.
Dark Zeiro
Mar 11, 2015 07:15 AM
jb4xx
Feb 2, 2015 10:00 PM
David Dorris
Jan 17, 2015 08:10 PM
Sarahrope64
Nov 27, 2014 11:17 AM
cASe SenSiTive
Sep 1, 2002 02:37 PM
