fuel pump relay?
Old Oct 8, 2006 | 03:02 PM
96Black RS's Avatar
fuel pump relay?
My car will not start.I think the relay is bad.When I turn the key to the on position the relay clicks like a machine gun will not stop untill I turn key off.Is that what a bad relay sounds like?
Old Oct 8, 2006 | 03:09 PM
lt11997's Avatar
Re: fuel pump relay?
Take a paper clip and jump the relay terminals and if it fixes your problem you know it's your relay. You can also just swap relays with a known good one too.
Old Jun 18, 2007 | 10:10 AM
NoItsNotForSale's Avatar
This is what my car is doing now. 95 camaro V6 A new relay did not fix the problem. Any Ideas? THANKS
Old Feb 18, 2008 | 09:57 PM
donman's Avatar
Wow I have this problem too. However it is very intermittent. Did you ever resolve this?
Thanks
Don
Old Mar 1, 2008 | 07:56 PM
donman's Avatar
Ok guys. I found my problem. I had two symptoms....
One where the fuel pump relay would click like heck...like a machine gun...
That was very intermittent.
Also intermittent, my car would not start. It would not prime and I could not hear the fuel pump relay click to prime the fuel pump. I found this the hard way. On a 0 degree night and the wind blowing like crazy. I called a tow truck and they said 30 minutes. So I decided to kick the left foot rest (where the relay is located) and the car started and made it home...
I bought a new relay, but that did not solve the problem. The problem was the connector. While the car was running, I wiggled the wires going to the connector and the relay would respond (click) and sometimes the car would die.
I just replaced the connector (about $27 for the part). Now the relay does nothing when I wiggle the wires. I think I have finally fixed a problem I have had, intermittently, for the last couple of years...WooHooo
Don
Old Apr 17, 2008 | 09:54 PM
donman's Avatar
Just a follow up, my #$%&#@# fuel pump relay chattered like a machine gun the other night. Had to have my car towed home. Next afternoon it starts fine..
I am sick of dealing with it and going to look for a 2002 WS6...
This thing is so intermittent it makes my car useless, since I never know when it is going to do it..
Don
Old Apr 24, 2008 | 09:49 PM
donman's Avatar
Guys here is another update. My firebird is getting less reliable. This fuel pump relay problem is very intermittent. However tonight it stayed for a long time. I had my friend over, who is a mechanic at a dealer. We back probed at the fuel pump relay. I only had 9.6v at the green/white wire. He said I should have more there. So we jumpered 12v to the green/white wire and the relay energized and the fuel pump ran. Unhooked the wire and we were back tothe relay chattering like a machine gun. Trace the Green/white all the way back to the PCM. I had the same voltage coming out there. So I tried wiggling the connector no luck. I tapped the PCM with one of my rachets and everything started working.
So it either one of the connectors on the PCM or the PCM that is bad.
I will post more when I figure it out. I just wished I had a pcm laying around here :-)
BTW...I gave up on this 96 V6 firebird last week and bought a 2002 WS6 Collector Edition TA.
Little did I know we would be able to trace this back so quickly. I have been fightning this for over 3 yrs. It was very intermittent, but it is starting to show itself more and more now.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
