What should I run?
Old Oct 3, 2006 | 10:03 PM
SLeeper94Z's Avatar
What should I run?
Im planning on 383 stroker, Le2 heads and Custom nitrous cam..
Car will be around 3100-3200 pounds,TH350 Tranny,4500 stall,373 gear stock 10 bolt... and spraying at least a 200 shot..... Can anyone tell me what I should run in the 1/8 mile and 1/4 mile... and mph?
Thanks
94 Z28
Old Oct 3, 2006 | 10:24 PM
myslowcamaro's Avatar
Re: What should I run?
what type of tire?
Old Oct 3, 2006 | 10:30 PM
SLeeper94Z's Avatar
weld wheels, Et streets or Mt streets
Old Oct 4, 2006 | 01:18 AM
Chopstix's Avatar
Thanks
94 Z28
600+lb/ft and 10 bolt should not be uttered in the same sentence
If you get the car to hook it should run at least mid 10's @ 130
Old Oct 4, 2006 | 05:55 PM
CamaroRacing12's Avatar
can u say busted rear ends?
Old Oct 4, 2006 | 06:30 PM
TedH's Avatar
If it doesn't break and you hook up you should be in the sixes easily in the 1/8, however if it hooks you may be picking your rear off the ground. hopefully you have a driveshaft loop, at least a six point bar, a fire bottle, open lugnuts, a tranny shield/blanket, and maybe some wheelie bars...
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
