Any harm running a WAY bigger than needed fuel injector if tuned right?
Old Sep 30, 2006 | 07:37 PM
HardcoreRM125's Avatar
I plan on building a low compression stroker motor that will see 14+ psi ...
BUT, in the mean time I wanted to run around 7 psi, on my stock bottom end. Until I have all the money to do everything right on the motor.
So say I was to get 72lbs injectors, could I get the PCM set for them, stock pressure, to run on 7 psi, just fine with no drivability issues, that way later on down the road I can use the same injectors and wont have to buy them twice?
Otherwise, I would probably find myself a set of 42#'s for now. Sell them off, and go bigger later.
Pro's/Con's ? Opinions?
Old Sep 30, 2006 | 07:48 PM
ramair96ws6's Avatar
Re: Any harm running a WAY bigger than needed fuel injector if tuned right?
go with the 42s and buy the bigger injectors later. easier to tune. less money
Old Sep 30, 2006 | 09:35 PM
rskrause's Avatar
The largest high impedance injectors that are readily available are in the 50# range. You could run those, not a problem. The stock PCM will not run low impedance injectors - the drivers will overheat.
Rich
Old Sep 30, 2006 | 09:57 PM
Thanks guys ...
I dont know why, I had it stuck in my mind someone had a 72# high but Owell ... Ok thanks.
Old Sep 30, 2006 | 09:59 PM
jerminator96's Avatar
Is there any problem with running injectors that large though? Assuming you got either an impedence converter or aftermarket pcm.
I'll be running 72lb injectors on a car that needs ~65lb. I'll be using them to there full capacity later, but until then...
Edit: I think there are some 72lb high impedence injectors, i'll see if I can't find them.
Old Sep 30, 2006 | 10:02 PM
So if I did buy the injectors now, which brands would you guys be looking at?
I can get Lucas ones at a good price. But if the SVO's show an advantage, I dont have a problem chipping out the cash for them.
O and I would be looking at 42#'s I guess then since I would have to upgrade later anyways. Thats more then enough for a bolt on, 7PSI blower car on stock heads and cam.
Old Sep 30, 2006 | 10:07 PM
http://www.usrallyteam.com/injectors.html
Down the page there are some 750cc injectors (72lb/hr) that are high impedance. They're made for VW's and such but i'm sure you could get them to work
Old Sep 30, 2006 | 10:18 PM
Hah actually, I think those are the ones I remember seeing in a GM Hi-Tech Mag. ....
Old Sep 30, 2006 | 10:19 PM
It jsut seems like switching to low impedence is going to be overly complicated/expensive so maybe I will wait until later to do it all.
And Ill get myself some SVO or Lucas 42#'s ...
Old Oct 1, 2006 | 01:10 AM
CALL911's Avatar
Later when you upgrade, you may want to look a little bit before committing yourself to 72# injectors. Personally I am running Mototron 60# injectors and spinning just underneath 16#'s of boost (15.7 to be exact). I have been told that they will support over 18#'s of boost effeciantly if needed.
Remember, you want the injector size that is best for the application you will be running. Anything outside of the size that would best fit your setup and you will not be running as efficiantly and may loose HP.
Old Oct 1, 2006 | 10:29 AM
z96's Avatar
z96
i built my engine low compression and running 60lb motron injectors. pcmforless tuned my pcm to run with these injectors with no super charger on their until i get the money to by it. i donot fluid engine at all and not running rich.
Old Oct 1, 2006 | 02:32 PM
Well, the 72's were just a estimate really, I basically just want something that can support in the 600-700RWHP range, and hopefully I can do so on the stock PCM but its gonna be tough getting a set of high impedence injectors that will cut it ...
Those 60# mototrons, their high impedience, Any problems with them on the stocm PCM? What fuel pressure are you running? I could always run them, with an AFPR to keep from having to use a impedence converter or aftermarket pcm.
Old Oct 1, 2006 | 11:18 PM
Rodrigues's Avatar
From first hand experience on friends cars the 75lb injectors purr like a kitten and 96lb (1000cc) run fine as well. If you plan on needing bigger in the near future just get the bigger ones now. I just installed 160lb injectors on my car and hope for the best!
Old Oct 2, 2006 | 01:03 AM
Rodrigues, those are low impedience though correct?
Old Oct 2, 2006 | 01:19 AM
Rodrigues's Avatar
the 75lb injectors are high impedance made by RC Engineering.
My 160lb injectors are low and would required a peak and hold driver.
