Any harm running a WAY bigger than needed fuel injector if tuned right?
Old Oct 2, 2006 | 06:28 AM
  #16
CALL911's Avatar
Re: Any harm running a WAY bigger than needed fuel injector if tuned right?
Again, IMO you can certainly run a higher than needed injector size, but it certainly won't be efficiant, and you will loose potential HP.
My fuel pressure once my 2nd fuel pump kicks in at 4#'s of boost shoots up to 60. As you can see in my sig, I am still running the stock PCM with pump gas and no problems. My setup could probably be pefected if I swapped out my ported AFR 180's with some 220's. On a better day temperature wise and re-dyno'd on a dynojet I could have easily seen 650 at the wheels. I am sure swapping out for the better heads I could have gained an additional 50 RWHP if not more. (So yes 700 RWHP is attainable with the stock PCM, but it is expensive and not easy to accomplish) Here's a link to my dyno video;
http://videos.camaroz28.com/video/5d...2b00ebf51d.htm
Old Oct 2, 2006 | 09:28 AM
  #17
RealQuick's Avatar
Motron 60's would be a good choice for ya.
Old Oct 2, 2006 | 12:44 PM
  #18
HardcoreRM125's Avatar
You think I could get 60's to provide enough fuel later on down the road when it is regularly going to see high boost on a 383 ? The heads will likely be LE3's ... I want to see how far I can go with the stock castings.
But ya never know, I may decide to throw some more $$$ at it and get AFR's ?
How can you loose potential horse power? If you are keeping a good spray pattern, the only thing different is going to be that it will have a shorter pulse width ( For now ) ... I dont understand what makes you loose potential horsepower by going "too big" with the injectors?
Old Oct 2, 2006 | 12:48 PM
  #19
RealQuick's Avatar
I have seen the 60's support 700rwhp on LS1's (though they run higher fuel presure 60-65psi base). This means if you have enough pump and a good regulator you could take the 60's to 700rwhp as well.
Old Oct 2, 2006 | 12:51 PM
  #20
Hmmm ...
Alright thanks guys ...
I guess I have a little more research to do on this still, but you awnsered alot of my ?'s ...
AdsoYo
May 2, 2018 03:21 AM
Jul 4, 2005 05:00 PM
Eric H
Aug 10, 2002 06:39 AM
XtremeLt1
Aug 1, 2002 11:25 AM
mjcent922
Jul 27, 2002 12:42 PM
