Monoblade thottlebodies
Old Sep 27, 2006 | 12:40 AM
LT1runner's Avatar
Is it worth it to go from a 58mm to a monoblade TB on a forced induction application? Would the car being a turbo or supercharger car make a differance?
Old Sep 27, 2006 | 01:59 PM
HardcoreRM125's Avatar
Re: Monoblade thottlebodies
You would probably notice some WOT gains on your Vortech car at 15 PSI.
Alot of people say you definatly loose low end running a Monoblade ...
But if you already have a 58MM I see no reason to upgrade. If you DONT have a 58MM yet though, then I could see maybe buying the monoblade. Not alot of people are running them so trying to find anything out about them can be a little tricky
Old Sep 27, 2006 | 03:19 PM
T/A KID's Avatar
IMO I really don't see that happening. The LT1 intake lacks Plenum Volume, and they can benefit from Bigger TB"S always. A monoblade give the LTX intakes more Plenum Volum which in Turn means more Hp and TQ???
I have a D1SC, 383, with AFR heads and I have a Monoblade if that matters.
I'll let you guys know how everything goes when we take it to the dyno.
Old Sep 27, 2006 | 06:51 PM
SiDeWaYZz28's Avatar
I have a monoblade about to take my intake off today port it and Ill keep you posted on the gains
Old Sep 27, 2006 | 08:23 PM
ru2slo_99's Avatar
My monoblade will stick open when the motor sees over 10 psi. I was quite scary when it happened. I have not driven it or tried to fix the problem since it stuck.
Old Sep 27, 2006 | 09:56 PM
T/A KID's Avatar
I believe advance has an AUX spring that fits the monoblade and people tend to use it on Blower setups b/c the factory spring is not strong enough to shut the blade.
Old Sep 27, 2006 | 10:08 PM
^ Thats kinda common with them apparently. I was thinking of buying one off of Alvin from PCM4less, and he told me that, it too, flares when shifted at WOT. Enough to be a little scary I would think.
FWIW, the end goal I am shooting for with my car ( Once I get a stroker/blower combo goin ) is going to be either a 58MM or monoblade. I wont buy a monoblade new because the price is kind of hard to justify without seeing someone else do a before and after. But if I come across one used, you can bet I am going to jump on it.
People have claimed to loose low end TQ with them, but I take it for what it is ... Their two completely differnet throttle body designs, so to drive, it may very well feel like you have to press the pedal further to open it the same amount as the twin 58's or something. And dynoes only tell half the story. Itll show you gains across the board at WOT, so they very well may feel "different" to drive. In reality though, your talking about putting it on a V8 BLOWER car. Its already going to be making more than enough low end TQ, and if you notice a difference, really, is it going to hurt you at that point? For what you may gain on the top end, I say its worth it if you get one at a good price, and go for it. Just be carefull with the sprigns nad ****.
Old Sep 28, 2006 | 09:17 AM
LT1runner's Avatar
Thanks for the replies. Who else is selling these things. I've looked around, and can't find who's selling them to see a price on these bad boys.
Old Sep 28, 2006 | 01:14 PM
Call A&Z dirrect they gave me an awesome deal to low that I dont think I should list here.feel free to pm me
Old Sep 28, 2006 | 01:43 PM
On ASM's web site, they go for like 600ish? I forget now.
sleeperZ96BT
Sep 9, 2015 08:28 AM
MAKQSIK
Parts Wanted
Jun 11, 2015 04:30 PM
fast 93 z
May 5, 2005 08:23 AM
WHYTLIE
Advanced Tech
10
Mar 7, 2005 07:28 AM
