cam ?????????
Old Sep 20, 2006 | 05:45 PM
saxmo's Avatar
cam ?????????
Hey guys, I am no cam guru, so maybe one of you will know if my cam is streetable or not. I am building a motor (1995 LT1) and I have a parts engine that I am robbing good stuff out of... eagle forged crank, H-beam pushrods, SRP -5cc forged pistons, etc. the donor motor was gonna be strictly track car, so I feel like the cam may be too big for me. I know the other parts are prolly overkill, but I already had 'em, so I figured what the heck...just use 'em. Here are the cam specs...
SERIAL # G 4224-05 SPEC CARD # 08998505 SPEC CARD INQUIRY BY
SERIAL #
PART # 07-000-8 LT1 CS LT1 ROLLER
CORE C07-8B LT1 DUCT SEMI (H.L)
Special Grind
GRIND # LT1 3017S /3113S HR112.0
DURATION @ .050 INTAKE 236 ROCKER
ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 242
INTAKE 1.50
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3630
EXHAUST 1.50
VALVE LIFT INTAKE .544 LOBE LIFT EXHAUST .3670
VALVE LIFT EXHAUST .550 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 286 CAM ADVANCE 0
TAPPET LIFT EXHAUST 304 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 6 JOURNAL DIAMETER STD 1.868
VALVE OPEN EXHAUST 53 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 50 DEPARTMENT P
VALVE CLOSED EXHAUST 9 SPC INSTR FOR CUSTOMER
will it work for a street car? (54mm TB, 30#SVO injectors,pacesetter LT's, 1.6 magnum RR's, 3.50 crank, -5cc forged pistons,stock heads, but great valvetrain!)
Old Sep 20, 2006 | 11:59 PM
street demon2k3's Avatar
Re: cam ?????????
car should run pretty good with some tuning. stock heads might be pushing it with that big of a cam, it should run good though. i think the gm 847 cam is as big as that one and there are some people that run it on stock heads. good luck with it, post up some numbers when you get it together. im about done with my LE2 cammed 355 with stock heads, and it runs pretty hard maybe 340-350 hp but im shooting for low low 12's@110 at the track.
Old Sep 21, 2006 | 12:50 AM
saxmo's Avatar
Re: cam ?????????
i read some cam articles that stated the 236 duration would make for a real choppy idle..and would not sustain power brakes... is that true?
Old Sep 21, 2006 | 06:26 PM
Re: cam ?????????
just get some good tuning, but there shouldnt be a problem with the brakes. my friend has an xfi 240/246 in his 355 and another has a formula 383 afr's and a 242/248 both run fine and are daily driven more than 30 miles in traffic.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
