Race at track w/ tops off?
Old Sep 17, 2006 | 01:27 AM
Bayer-Z28's Avatar
Didn't think this was drag "Technique" so I posted here.
Is there any reason I cannot race at the track w/ my t-tops removed for weight reduction reasons?? Was having thoughts right when I woke up this morning, was thinking about emptying my car before I go to the track. The !tops would prolly be worth about 7-10 lbs, I'd immagine.
Are there rules for this?
Old Sep 17, 2006 | 01:40 AM
LT1 POWR's Avatar
Re: Race at track w/ tops off?
I know at the local track you have to have your top and windows up if you have a vert and your windows up if your a coupe. There were a few t-top LS1's at the track last night, they all had their t-tops on. Im not sure if they had to or not, i never asked them, but if they make you put your windows up, there is a good chance your not allowed to have your t-tops off. Safety reason, im sure. Also they probably dont want stuff flying out of your car and onto the track. A few years ago my brother in law had a 96 vert cobra and i remember him going down the track with the top down, but they have changed their rules a bit since then. Im not sure if this just applies to this track or its a NHRA rule or something. Maybe you could get someone with a rulebook to look it up for you.
Old Sep 17, 2006 | 06:29 AM
twozs's Avatar
your kidding right? any weight reduction you"ll gain by leavind the tops off you"ll loose in areo drag with the tops off. empting the car is a good idea (each 100 pounds =.1 in time) but in a car thats shaped like a wedge why screw with it
Old Sep 17, 2006 | 07:33 AM
wrd1972's Avatar
The drag will kill your HP.
Similar to my vert, I know I lose big HP when the top is down.
Old Sep 17, 2006 | 07:58 AM
Javier97Z28's Avatar
Lol
Old Sep 17, 2006 | 12:10 PM
GhostZ28's Avatar
Yeah, for me top down at 100+mph my car is a dog.
Old Sep 17, 2006 | 01:00 PM
Bayer-Z28's Avatar
ok... I never thought of the drag w/ the tops off idea.
As far as weight reduction, every little bit counts. But If it's a rule to leave the tops in, I'm not going to argue that.
Fine w/ me.
Old Sep 17, 2006 | 01:26 PM
Stephen 87 IROC's Avatar
Unless your track is very lax on the rules, you can't race with the tops out as per the NHRA/IHRA rulebooks. I managed to find some Lexan tops out of a 92 Formula for my car. They cut a few pounds off.
The rules state that full bodied cars must have a full top and windshield. That means the convertibles must have the top up and T-tops must be in.
Old Sep 17, 2006 | 06:03 PM
LT1 POWR's Avatar
Im sure you dont "lose" hp with the top down, but your mph might suffer due to the extra drag, causeing the effect of less hp.
Old Sep 17, 2006 | 06:17 PM
GhostZ28's Avatar
I was actually thinking of making a set of plexiglass Ttops that you could swap out for the glass. It would cost me around 5 thousand to do this, but since it would only save like 10 pounds, do you think I'd have a market there?
around 5 thousand dollars for the first set, then every other one.. I cant tell or by little idea would be screwed..
Old Sep 17, 2006 | 08:51 PM
GhostZ's Avatar
We've let cars run without tops as long as they have a full cage.
Old Sep 17, 2006 | 10:29 PM
GhostZ28's Avatar
wow its my nemisis.. GhostZ..
Old Sep 19, 2006 | 01:30 PM
GhostZ's Avatar
Maybe you're the reason I had to use GhostZ28 on another board
Old Sep 19, 2006 | 08:05 PM
wrd1972's Avatar
Thats what I should have said, thanks for the clarification.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
mark0006
Mar 21, 2015 12:32 AM
Mar 15, 2015 07:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
