n20 question
Old Sep 16, 2006 | 10:02 PM
Daniel6718's Avatar
n20 question
i have a wet kit and mallory box...my tuner said i should be ok with no timing pulled on a 75 shot...well i hit it the first time today on a 75 and pulled 6 degrees, had the window at 35-5500 and it poped about 3 times from 4000-6500...what causes the pop?
daniel
Old Sep 16, 2006 | 11:46 PM
01Z's Avatar
01Z
Re: n20 question
I was having a conversation with camzaro28 and he had the same thing. As he removed less timing the popping went away. I understand why you want to play it safe but 6 degrees is a lot of spark retard. My thinking is that you are sparking so late in the combustion cycle that enough gas goes unburnt out the exhaust that it is building up there and igniting. Hence a small explosion outside the combustion chamber.
Old Sep 17, 2006 | 01:52 AM
Daniel6718's Avatar
Re: n20 question
yea i know..it was tyhe first hit and i could feel it...i dropped it to 4 and pout 100 in there...so im pulling an extra 2 degrees but i can drop in 150without doing anything else
i found out the popping occurs without the n20 also...didnt think it was the problem but i changed plugs today too...i guess 36 degrees of motor timing and .35 gap dont like eachother...how far a gap can you go on a 150 shot? can i up it to around 42
?thanks
Old Sep 17, 2006 | 01:54 AM
Daniel6718's Avatar
Re: n20 question
currently at 35...i dont think timing is the issue...its the plugs...
Old Sep 17, 2006 | 09:25 AM
camzaro28's Avatar
Re: n20 question
well i am spraying a 150 adn the timing is it stock settings on the mallory. if i pull any out, the car pops alot. try the 100 with 6 pulled, then do it with nothing pulled and post the results please.
Old Sep 17, 2006 | 02:56 PM
Daniel6718's Avatar
Re: n20 question
no im not goana roast the motor or anything...i know it a problem with my plugs...
Old Sep 17, 2006 | 07:21 PM
camzaro28's Avatar
Re: n20 question
i changed out all my plugs today. ill let u know if that fixed my problem or not. not sure when i am going to spray it again though
Old Sep 17, 2006 | 07:30 PM
Daniel6718's Avatar
Re: n20 question
mine does this without using the nitrous! this is a problem with the plugs in general not only on the juice!!!!!!!!!!!!!!!!! its a plug question...how wide can you go on the gap????
and what is the problem with going wider????
Old Sep 17, 2006 | 08:56 PM
camzaro28's Avatar
Re: n20 question
maybe someone else can answer that for you
Old Sep 18, 2006 | 06:42 AM
01Z's Avatar
01Z
Re: n20 question
Because the nitrous causes the chamber pressure to soar the spark becomes less effective and disrupted. Closing the plug gap insures that the spark is strong and fat albeit shorter. That is why people go to iridium plugs and higher voltage coils to regain the gap size. You will have to take my information lightly as I'm regurgitating what I have read, or think I have read. I am new to nitrous myself.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
T/A lt1
Oct 10, 2002 03:14 PM
PhantomTA
Sep 7, 2002 08:44 AM
T/A lt1
Sep 5, 2002 06:53 PM
