Security Light
Old Sep 10, 2006 | 11:18 AM
IrishThunder's Avatar
Security Light
I currently own a 1994 Camaro Z28 and I love it, but as of yesterday it has stopped starting. For some reason, the security light on the dash has come on. I don't think it is a problem with the key (cleaning the key is a solution the owner's manual suggests) because I backed it up out of the garage and then, when I went to pull it in, it wouldn't start.
How do I reset or turn off this security system so this car starts again?
Old Sep 10, 2006 | 12:58 PM
tapout911's Avatar
Re: Security Light
Do a search for vats bypass and you will find the answer. Pretty easy to do.
Old Sep 10, 2006 | 02:40 PM
2001NBMZ28's Avatar
Re: Security Light
Welcome to the board. Visit http://shbox.com
Old Sep 10, 2006 | 06:17 PM
Re: Security Light
Thanks. I didn't even know what to search for on Google, so I didn't get a whole lot of results...
Well unfortunately I don't have a resistor lying around the house, nor do I have the ability to get the resistance value from the key.
Am I stuck taking it to the dealer or making a new key?
Old Sep 10, 2006 | 09:54 PM
tapout911's Avatar
Re: Security Light
Sometimes a new key doesnt fix it. I got resistance to my key by getting a maintence man at my work to check it with his ohm meter. I went to radio shack and got the resistors I needed to make it work.
Old Sep 11, 2006 | 06:13 AM
Re: Security Light
Well, thanks, it appears I'll just have to get it towed to the dealership and they can fix it there.
Thanks again.
Old Sep 11, 2006 | 11:40 AM
01Z's Avatar
01Z
Re: Security Light
I really hope you can fix this yourself or at least have a friend help you. Towing a car to a dealership and having them fix it is going to cost you huge.
Take a look at these links:
http://shbox.com/1/4th_gen_tech2.html#pass_key
http://shbox.com/1/vats_bypass.jpg
Old Sep 12, 2006 | 06:14 AM
Re: Security Light
Turns out the starter needed to be replaced...
The security light was on, but it was because starter was just defective....
$300 later and at least it will work...
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
