Simple A4-M6 swap question
Old Nov 13, 2002 | 12:00 AM
96z's Avatar
96z
When you do the swap what do you do? Just reflash your PCM with an M6 specific program?
Old Nov 14, 2002 | 12:11 AM
SteveR's Avatar
Yes, and the car will run/drive with the A4 program. It will throw some tranny codes because the A4 isn't there, but other than that it is fine. There is no such thing as an A4 PCM or an M6 PCM. Both PCMs are the same part #, they just have different flash files loaded.
Old Nov 14, 2002 | 09:01 PM
96z's Avatar
96z
Really?? So I can leave the computer as is with my A4 program and drive it with no problem besides codes?
Interesting....Ill probably reflash it with a M6 program anyway, thanks!
Old Jan 6, 2003 | 01:16 AM
Lt1tko5o's Avatar
You willhave to change your Vss calibrations for the M6, I did the reverse swap and my speed O was way off, had to flash in the A4 program and the speed O is now accurate.
Brian
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
