Help with lights...reverse, brake & signal
Old Aug 26, 2006 | 04:45 PM
jayig's Avatar
Unhappy Help with lights...reverse, brake & signal
My reverse lights work when they want... Sometimes I have to put the stick between p and r to make it work. My signal and brake lights don't work at all. I've changed the fuses, the brake light switch and the signal flasher but still no luck... Suggestions please anyone before I get a ticket?
Old Aug 26, 2006 | 06:55 PM
lastZ's Avatar
Re: Help with lights...reverse, brake & signal
and your car is?
Old Aug 27, 2006 | 08:11 AM
1st TA's Avatar
Lightbulb Re: Help with lights...reverse, brake & signal
Have you used a test light at the brake light switch to see if you have power after the switch? If you do, check at the rear of the car to see if it makes it there. If it does and the lights don't work than it is most likely a ground problem.
Henson071
Sep 18, 2015 04:01 PM
cohopefull
Sep 8, 2015 03:22 PM
4586
Aug 22, 2015 01:09 AM
Boss002
Jul 24, 2015 10:47 AM
