stock bose subwoofer
Old Aug 23, 2006 | 11:33 AM
Beyonce Knowles's Avatar
i know this is wrong place for this, but I need help kinda quick and the audio sections runs a little slow.
Can anyone give me a brief description of the factory Bose subwoofer and how it is wired? Does it serve as an amp for all 5 speakers or just the sub? Does the output from the headunit send the signal to the subwoffer and it then sends it to the speakers?
Old Aug 23, 2006 | 11:40 AM
Blue89Bird's Avatar
Re: stock bose subwoofer
on a factory 5 speakers bose stereo, the front speakers each have their own amp attached to the factory enclosure, and the rear bose sub has its own amp attached to its enclosure as well, the rear speakers are powered off of the head unit.
Old Aug 23, 2006 | 12:03 PM
TraceZ's Avatar
A "bose" head unit does not power any speakers. I've had a few of them and currently run one in my Z. All 4 outputs are line level. front rear, left and right.
I know you are correct with the front speakers having their own little amps attached to them. I also know the subwoofer has its own amp attached to it. I dont know how the sail panel speakers are powered.
Now that I think about it... in 1994 the cars with Bose systems only had the 3 speakers. There were not any speakers in the sail panels. I'm trying to recall if my old 95 had them there, but I dont think it did either. In any event, I know 100% for sure that all 4 outputs on my Bose head unit are in fact line level. There is no amp built in.
Old Aug 23, 2006 | 12:12 PM
Blue89Bird's Avatar
well, I pulled the rear speakers out of my 95 bose car, and there were no amps attached to them. I had already removed the rear bose enclosure, so that wasn't there and they still worked, I also had the front speakers out, and the rears still worked, so I don't know where they would be powered from other then the head unit
Old Aug 23, 2006 | 12:17 PM
I'm looking at it now and the two wires that connect to the sail panel speakers come from the Bose sub.
I'm so effing confused right now.
Old Aug 23, 2006 | 12:26 PM
Blue89Bird's Avatar
it's possible the rears are powered off of the rear sub amp, maybe my car was rewired at some point.
Just unplug the rear sub and see if the speakers stop working, if so you know where their powered from.
Old Aug 23, 2006 | 12:27 PM
TraceZ's Avatar
Man, that's a tough one.
Maybe there are two different Bose heads? One for the 3 speaker and another for the 5? It's possible I have just never seen one for a 5 speaker setup, although I did own a 95 at one time and had it all apart. Could it be the amp for them is behind a panel under the hatch somewhere? I wish I had a better recollection of my old 95.
Old Aug 23, 2006 | 12:53 PM
JasonD's Avatar
Admin Emeritus
That's because everyone posts thair audio stuff in the wrong place, like the lounge. If more people posted their audio stuff in the audio forums, that would inherently be more people in the audio forum.
Old Aug 23, 2006 | 01:13 PM
Well my car has obviously been rewired. And crazily, at that. The front speakers (aftermarkert) and the stock sail panel speakers are all powered via the aftermarket head unit. Just a straight line from the head unit to each speaker. Now the question is how to get the sub to work. Looks like there are only 3 input wires, the other 6 are output (3 to each sail panel speaker) I found the end of the 3 input wires behind the head unit, which are currently cut and attached to nothing. Guess my best bet is playing around with hooking them into the sub out lines until something happens.
Old Aug 24, 2006 | 05:50 PM
Blue89Bird's Avatar
that "amp" needs a few things to work:
1. a signal
2. power/remote turn out.
You need to figure out how to power it first, there should be a wiring diagram on shoebox's site. Look for which is the remote turn on for it, and hook it to your new stereos remote turn on wire.
Then signal, you're not going to be able to hook it up to your sub out lines, as they are RCA jacks, and the bose sub has line level inputs (just speaker wire). Your best bet is pulling a signal off the rear speakers somewhere.
MyShibbyZ28
Feb 14, 2015 12:05 PM
Achilles97
Sep 13, 2002 10:49 AM
MJ_Z28
Aug 7, 2002 07:15 PM
jwright3SS
Jul 30, 2002 03:49 PM
CobraEatr
Jul 29, 2002 11:46 AM
