How to hot wire???
Old Aug 21, 2006 | 03:59 PM
jssws-6's Avatar
How to hot wire???
I think my Ignition is bad. What happens is, when I turn the key to the on position, only the radio will come on. The dash lights do not light up. The headlights work so does the horn, etc. But the car won't start. It won't even turn over. I need to limp this car home. Any suggestions?
Old Aug 21, 2006 | 04:00 PM
Dave89IROC's Avatar
Re: How to hot wire???
get a new ignition switch, unplug the old one, plug the new one in, and use a small screwdriver to work it
Old Aug 21, 2006 | 04:25 PM
jssws-6's Avatar
I little more help than that please. Elaborate thanx
Old Aug 21, 2006 | 04:29 PM
Dave89IROC's Avatar
like?
there are a half dozen wires that need to get power,. along witht the start wire, plus, the key needs to be turned on(to unlock wheel, and have the VATS signal OK)
easiest way is a new/working switch, plugged into the harness, switch is mounted on top of the column, halfway down to the firewall
Old Aug 21, 2006 | 04:36 PM
jssws-6's Avatar
Thats alot mre help thanx. The switch is that a gm only part, a local parts store would'nt have this would they
Old Aug 21, 2006 | 08:41 PM
Dave89IROC's Avatar
should be able to find local, probably in the brand "Standard"
Old Aug 21, 2006 | 09:18 PM
94Z28WP's Avatar
I replaced mine following shoebox's site:
http://shbox.com/ignsw/ign_switch_repl.html
Old Aug 22, 2006 | 10:44 AM
RE AND CHERYL's Avatar
When you try to start the car is the security light on? If so you might have a VATs issue.
Critter
Jul 7, 2015 08:33 PM
GigaMp3z
Feb 20, 2003 02:57 PM
CLEAR
Aug 30, 2002 07:49 PM
