Fuel filter placement & braided line routing
Old Aug 20, 2006 | 01:51 PM
blown383's Avatar
I'm looking for pictures of the way you guys routed your braided hose from the tank to the rails. I have a 12 inch long fuel filter that I'm having difficulty finding space to mount so I thought it would be easiest to mount it in the drive shaft tunnel. What do you guys think?
-B
Old Aug 20, 2006 | 08:34 PM
Re: Fuel filter placement & braided line routing
I have an SX fuel filter, and while its only about 8" long, I managed to mount it in the stock location. Braided lines from the tank to the filter follow the stock routing, although the inlet and outlet ends of the filter are swapped. Then the lines run forward and up under the firewall to the back of the engine, splitting in a "Y" to the back of each fuel rail. The return comes off the diagonal cross-over pipe in the front of the rails, to a Weldon AFPR under the cowl, then back down under the firewall, returning to the tank following the stock routing.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
Wilson
Jul 21, 2002 05:08 PM
