Solid Motor Tranny Mounts?
Old Jul 30, 2006 | 12:11 AM
Patryn's Avatar
Looking to pick up some solid motor and transmission mounts for my 2000 Z28. Can you guys post me a link to somewhere that is selling these. Looking for solid mounts, and not poly etc. Thanks!
Old Aug 1, 2006 | 07:49 PM
Patryn's Avatar
Re: Solid Motor Tranny Mounts?
bumping
Old Aug 1, 2006 | 08:04 PM
s10er8's Avatar
www.moroso.com
Dude I know you didn't ask but are you sure you want solid mounts? It will crack your transmission housing/bellhousing if it's stock
Old Aug 1, 2006 | 08:43 PM
ttop1986's Avatar
Just get some polyeurothane ones.
Old Aug 1, 2006 | 08:44 PM
Patryn's Avatar
I used 4 solid mounts for my 3000GT and its pushing about 600AWHP. So far my experiance with solid mounts is good, but I am basing on that platform. The camaro, I have not really modded to much. I do know that I hate the rear end jumping around and the engine and tranny clunking on hard launch. I would like it to be tight and solid. So with with that being said what should I mod at the same time if I do solid mounts if cracking the bell housing seems to be a problem for the Camaro. I didn't find too much info searching around.
I'm going to go solid unless its a confirmed/well known problem with solid mounts, not interested in poly.
Old Aug 1, 2006 | 09:00 PM
matLT1's Avatar
Why would this crack the bellhousing??? I'm interested in an explaination myself...
Old Aug 1, 2006 | 09:08 PM
Patryn's Avatar
Found some Spohn solid motor mounts and they do recommend using a poly tranny mount so seems like they may have some R&D into this too. So whats the consensus out there use solid mounts only on motor or motor & transmission. What is everyones experiance that has done these combinations.
Old Aug 3, 2006 | 06:11 PM
Patryn's Avatar
bumping, whats the info on this.
Old Aug 4, 2006 | 12:44 AM
stroked383z28's Avatar
I've run the Moroso solid motor mounts with a regular trans mount in my LT1 in the past. They are great mounts. You can run solid motor mounts with a rubber or poly trans mount. You just don't want to go the other way around (solid trans mount with rubber or poly motor mounts), because then you could crack the transmission case.
Old Aug 5, 2006 | 12:49 PM
Patryn's Avatar
Anyone ever tried to make any brackets or plates to reinforce the bell housing on the transmission. Just trying to find a way to lock everything down, get the car to have a tighter feel. Hate it when on hard launches seems like the transmission is just trying to jump around.
Old Aug 6, 2006 | 11:33 PM
95NateZ28's Avatar
I have solid motor mounts and a poly trans mount. The only real problem is the vibration transmitted throughout the car causes bolts to loosen. My car is a bit more extreme and I certainly don't drive it every day, but once every month or so I jack it up and go over all the nuts/bolts. I usually find a few missing, from exhaust collector to motor mount bolts.
Old Aug 7, 2006 | 05:15 PM
s10er8's Avatar
www.Moroso.com part#
or
mattszm6
Dec 14, 2014 07:09 AM
Nostang 96z
Aug 31, 2002 12:01 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
