Insulating Header Wraps (sorry if in wrong forum)
Old Jul 28, 2006 | 11:02 AM
86305Z28's Avatar
was thinking about picking these insulating header wraps up. Was wondering if anyone has used them and if you have noticed any difference.
The description from the Moroso Insulating Wraps says it "reduce underhood temperatures while producing more horsepower". Anyone actually notice or achieve any horsepower gain?
Im guessing the right way to wrap this is to have the wrap go half way over each other?
any and all thoughts comments are appreciated like always.
Old Jul 28, 2006 | 11:50 AM
87DJP2001's Avatar
Re: Insulating Header Wraps (sorry if in wrong forum)
Waste of money on steet car.
Old Jul 28, 2006 | 12:34 PM
86305Z28's Avatar
aight then. thanks.
Old Jul 28, 2006 | 12:36 PM
myslowcamaro's Avatar
unless you have repetitive issues with melting plug wires on certain cars. they also make spark plug wire sleeves for that too
Old Jul 28, 2006 | 01:18 PM
gota406's Avatar
We use then on roundy rounders, but it tends to hold moisture in and rust the pipes sooner. FWIW
Old Jul 28, 2006 | 02:38 PM
OBE1 95Z28's Avatar
Oil leaking over time on the header wrap creates a fire hazard; Tom Byrne had a car burn to the ground this way
Old Jul 28, 2006 | 03:51 PM
Just curious.... how could header wrap running at 1,100degF "hold moisture"?
Wrapped headers don't rust because of "moisture".... they rust because the wrap keeps the tube metal so hot the iron in the steel starts to oxidize = "rust". That's the problem with header wrap, it keeps the metal so hot that it loses its strength, embrittles and starts to oxidize and crack. That's not a big problem on a race car that has relatively easy header replacement, and where many parts are looked at as "consumables". But its a bit of a problem for a street car.
D1SC383LT4
Jan 1, 2016 01:56 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
brentbrowning01
Dec 16, 2014 06:35 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
