Stock gears to 3.73's = Hitting rev limiter?
Old Jul 12, 2006 | 10:14 PM
IROCThe5.7L's Avatar
This for my buddy. He has a 95 Z28, and put a new rear in with 3.73's. Now everytime his tranny gets to the top of first, he hits the rev limiter. People are telling him it's his transmission slipping. I could of swore I read about LT1's and LS1's having this problem after a gear swap. I was just wondering what needs to be done.
Thanks guys
Old Jul 12, 2006 | 10:41 PM
ttop1986's Avatar
Re: Stock gears to 3.73's = Hitting rev limiter?
he has to have his computer tuned, or his speedo will be off, and the shifts will be off....
Old Jul 12, 2006 | 10:43 PM
Thanks for the reply. Can anyone give me an explination? If the tranny is suppose to shift at 6000 rpm, why wouldn't it shift at 6000 rpm after the gears?
Old Jul 12, 2006 | 10:46 PM
ttop1986's Avatar
It depends on your speedometer reading, so if the speedo is off, it probably wont want to shift correctly.
Old Jul 13, 2006 | 12:18 AM
Zigroid's Avatar
mine did that when I went from 2.73s to 3.73s. had madz28 do a pcm for me and it was fixed.
Old Jul 13, 2006 | 11:52 AM
93yellowta's Avatar
don't want to hijack thread. but I have a 93 speeddensity, I went from 323's to 373's. and my speedo is off around 20mph. counting the 17" tires. anyway mine shifts way too soon also, so if I show it shifting at 6,200 on the rpm guage is that right, is it really 6200 rpm's. or is it sooner? is this the same problem? plus I can't change my computer. if I put in the speedo gear in the tranny to change the speedo will that fix it..thanks
Old Jul 13, 2006 | 01:12 PM
shoebox's Avatar
The shift is based on speed not RPM. If the speedo is off, the shifts wil be too. He needs reprogramming.
Old Jul 13, 2006 | 01:49 PM
frankthetank078's Avatar
just needs a reprogramming...your gears will change your RPM range relative to the speed your going.....look on pcmforless.com or madz28.com for a tuner. They can also calibrate his other mods into the pcm
Old Jul 13, 2006 | 01:51 PM
Great posts! Thanks again guys, much appreciated.
Old Jul 13, 2006 | 02:21 PM
OutsiderIROC-Z's Avatar
I learned something today.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
PCLZ28
Dec 24, 2015 05:19 PM
ChrisFrez
Dec 21, 2014 09:47 PM
