Installing Cam with both Heads offf?
Old Jul 7, 2006 | 11:35 AM
Heatmaker's Avatar
Advanced Member
From the Pro's, is it a good idea to install a Cam with the Heads off? I remember reading somewhere that it was best to have the heads torgued down first.
Old Jul 7, 2006 | 11:53 AM
SStrokerAce's Avatar
Re: Installing Cam with both Heads offf?
Nope I usually do it after I put the crank in. Easier to degree that way.
Bret
Old Jul 7, 2006 | 12:26 PM
rskrause's Avatar
Bret
Bret: you are such a scamp!
Rich
Old Jul 7, 2006 | 02:47 PM
lol
Old Jul 15, 2006 | 10:57 AM
user 647483's Avatar
That's the way all of mine have been done.
Old Jul 21, 2006 | 07:06 PM
Javier97Z28's Avatar
heads off.. as bret said, much easier to degree.
Old Jul 21, 2006 | 11:14 PM
84firebird's Avatar
yea... heads off, and if your block torques the camshaft when you torque the heads.... pull maybe 100 psi of torque off the head bolts, then have it re align bored.... head bolt torque shouldnt matter at all....
however they may have been doing a complete setup and they wanted the heads torqued to spec so they could check pushrod length and rocker arm alignment right away, too???
Old Jul 22, 2006 | 10:46 AM
Victory Racing's Avatar
I personally always install the cam with the heads off, I prefer that degree method than the heads on method. However it is all a matter of preference and what you personally prefer.
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Nov 20, 2014 06:03 PM
jmzlt1
Mar 13, 2003 07:26 AM
F(ast)-body
Feb 26, 2003 09:05 AM
