To Cut, Or Not
Old Jul 6, 2006 | 11:26 PM
JHawk833's Avatar
To Cut, Or Not
I'm considering cutting off the cat on my car, I just would like some advice on what the good and bad would be doing so. And, how much should it cost? Oh and on a similar note, I'm looking for new tips, do tips with resonators sound much better than ones without?
Old Jul 7, 2006 | 06:33 AM
teke184's Avatar
Re: To Cut, Or Not
cut it....CUT IT.....DO IT!!!!
the car will be louder, possibly a small amount of added rasp to the upper rpm tone. and you'll probably pick up 5-10hp or so.
just cut it out, take some measurements and go to a shop and tell them you need a piece of pipe xx" long with slip fit on each end.
most reputable shops won't cut the cat out...legally
Old Jul 7, 2006 | 01:29 PM
"White Knight"'s Avatar
Re: To Cut, Or Not
I wouldn't cut it out. No gain other than sound. Use the money elsewhere. Plus like he said most shops won't do it.
Old Jul 7, 2006 | 01:44 PM
2000GTP's Avatar
Re: To Cut, Or Not
I would do it if you don't have to worry about emissions restrictions. Several shops around my area do that kind of work but I guess when they do the paperwork, they put down that the car is for "off-road use only." Not sure how the whole "system" works, but some shops will work with you.
Old Jul 7, 2006 | 06:36 PM
94Z28WP's Avatar
Re: To Cut, Or Not
Did it with a pipe through the cat... It will give the exhaust a more raw sound... With my Hooker exhaust, it's a balance of the original Hooker tone with the raw sound... I wanted the exhaust louder and this did it... Not obnoxious, but not quiet at all... The exhaust will smell idling in traffic if you have the windows down.
Old Jul 7, 2006 | 08:44 PM
slayer6x6's Avatar
Re: To Cut, Or Not
I would just hollow it out so at least it looks like you have one.
Old Jul 8, 2006 | 10:22 AM
Craddock's Avatar
Re: To Cut, Or Not
I had mine cut out on my current car and my old car. If I could do it again I would have a pipe put thought a gutted cat cause when you try to get a sticker it takes a while to find someone who doesn't care about it. A lot of places around here won't give you a sticker with that cut out. Get a hollowed one or a pipe though a gutted one (preferably). I know I felt a small difference when I had mine taken off.
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
