No cold A/C...
Old Jun 25, 2006 | 06:40 PM
fragenstein's Avatar
No cold A/C...
Used to be fine... still blows hard, but not cold at all. Just noticed since the weather heated up again.
Where do I start to diagnose the problem, or is it a no-brainer? I know nada about A/C systems.
Old Jun 25, 2006 | 07:32 PM
MyShibbyZ28's Avatar
Re: No cold A/C...
You probably ran out of refrigerant. Go to walmart, or target, or where ever and get a recharge can.
If the compressor is not coming on in the engine bay then it is a different story. Have someone look at the compressor under the hood while you turn the AC on. If it engages then you probably ran out.
Old Jun 25, 2006 | 08:42 PM
Re: No cold A/C...
What will I see when the compressor engages?
Old Jun 25, 2006 | 08:59 PM
Cmr0z28's Avatar
Re: No cold A/C...
You'll see the front of the compressor spinning if the clutch is engaged.
Old Jun 29, 2006 | 08:40 PM
dubbsix's Avatar
Re: No cold A/C...
Wont the compressor not start if its low on refrigerant.. as it also serves as lubricant for the compressor?
Old Jun 29, 2006 | 09:40 PM
Dave89IROC's Avatar
Re: No cold A/C...
the compressor won't engage if the system is low on refrigerant
and it is lubricated by oil that is suspended in/circulated by the refrigerant, not by the refrigerant itself
Old Jun 30, 2006 | 10:27 AM
Re: No cold A/C...
So really I need to just add refrigerant? Don't you just use some hose kit and then the refrigerant cans?
Old Jun 30, 2006 | 03:03 PM
Dave89IROC's Avatar
Re: No cold A/C...
probably
just remember there is a leak, and it will just leak out again
get the can/hose kit that comes with a gauge on it, it will be labeled with a range that is good
Old Jun 30, 2006 | 11:28 PM
DrivingZiggy's Avatar
Re: No cold A/C...
Or it could be a relay. That just happened to me. It wasn't cold and when I looked down into the engine bay, I could see that the clutch wasn't turning. So I brought it to the A/C shop next to my mom's store. First they filled it up--it was only .7 pound low, so no leaks. That's to be expected in an 11 year old car.
Then he hooked up his scanner, which didn't work. So he finally found his loose wire and hooked it up again and found a bad relay.
Total bill: $100.86.
Old Jul 8, 2006 | 08:43 AM
Ace_437's Avatar
Re: No cold A/C...
Where exactly is this relay?
Old Jul 8, 2006 | 12:00 PM
Re: No cold A/C...
I think in the underhood fuse box.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
football4life
Oct 4, 2015 07:48 AM
greenzee28
Sep 25, 2015 04:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
