slp line locks question?
Old Jul 4, 2006 | 07:03 PM
ghost stripes's Avatar
how do you wire the line lock up does the post on the cylinder has a positive and negative ....when installed does the linelocks disable the brakes on the rear or lock the brakes on the front?...any pics of installation will be appreciated
Old Jul 4, 2006 | 08:07 PM
MyShibbyZ28's Avatar
Re: slp line locks question?
I believe it just locks the front up, and keeps the back open yet still functional.
Old Jul 5, 2006 | 09:49 AM
Red wire will be +12V, black wire will be ground.
The solenoid get installed in the line for the front brakes, running from the master cylinder to the distribution block on the side of the ABS unit. The front brake line is the one that starts from the rear of the master cylinder. When you put your foot on the brake, actuate the solenoid, and lift off the brake pedal, pressure is held in the front brake lines.
http://www.injuneer.com/images/photo...es/LineLok.jpg
Old Jul 5, 2006 | 04:57 PM
thanks will try this
Old Jul 7, 2006 | 10:38 AM
"White Knight"'s Avatar
I believe the SLP unit has both gray wires for + and -. I don't have any pictures of mine on hand. The wires can go either way as long as you have one on + and one on -.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
