ABS/ASR inop
Old Jul 3, 2006 | 07:40 AM
vdubois's Avatar
ABS/ASR inop
Today my ABS/ASR inop lights came on. They did it once before but shut off the next time i started the car. This is on a 1996 Z-28. My question is since its both lights that are on that would mostly likely point to a sensor in the rear of the car, right? If i go up to autozone and get the free otbII scan will that show me which one or do i have to do something else. Any help would be gratly appreciated because my dash looks like a christmas tree right now.
Old Jul 3, 2006 | 08:59 AM
teke184's Avatar
Re: ABS/ASR inop
use to happen regularly on my old 96. could just be that the sensor is loose. i'd check it first.
not sure if there is actually a code to it or not.
maybe try clearing the computer.
Old Jul 3, 2006 | 10:10 AM
rngilliland's Avatar
Re: ABS/ASR inop
You will need to go to the dealer or someone who has a Tech 1 or 2 scanner to get the ABS/ASR codes scanned. I would check the connections to the sensors and if that doesn't fix it get it scanned.
Old Feb 6, 2007 | 01:55 PM
vdubois's Avatar
Finally fixed this too. My right front sensor wire was smashed against the frame. Fixed!!!!!!!!!!! I now have 0 idiot lights on.
grabbem88
20
Dec 27, 2015 07:42 PM
pologreen97z
May 18, 2015 02:17 PM
jj_burchiel
Mar 21, 2015 12:51 AM
prockbp
Jun 22, 2003 12:19 PM
Apr 28, 2003 11:32 AM
