subframe connectors for 4th gen
Old Jul 2, 2006 | 04:19 PM
ztwenty8's Avatar
i found a really good deal on some subframe connectors, the ones i found were said to be a 98-02. correct me if im wrong, but i was under the imppression that the subframe connectors for a forth gen. were able to go on a 93-02? any imput would be much appricaited
thanks
mike
Old Jul 2, 2006 | 04:23 PM
Sylvrls1's Avatar
Re: subframe connectors for 4th gen
i think your right... do you know what brand you are buying? if so look at that brands web site or any like slp and find out the years. i would check to see if they are bolt in or weld in also...
Old Jul 2, 2006 | 05:01 PM
Misfits's Avatar
slp is from 93-02.. a few other brands r 98-02 and 93-97
Old Jul 3, 2006 | 08:14 AM
Some manufacturers (e.g. Spohn) make two different models of the SFC's for 93-97 and 98-02, because the fuel line routing is different on those years, and the front mounting point is right next to the fuel lines. On the Spohn SFC's, you can't use the 98-02 model on a 93-97.
Old Jul 3, 2006 | 11:33 AM
ztwenty8's Avatar
the ones im looking at a a kenny brown dd sfc. i saw some somes websites that say 93-02 and some that say 93-97 and 98-02. so im a little confusiused
Old Jul 3, 2006 | 04:33 PM
NOSCaMaRo's Avatar
MY UMI's are advertised 93-02. I think it is just the Spohn's that are like that
Old Jul 3, 2006 | 05:27 PM
2000GTP's Avatar
I think Spohn may have changed this because they advertise the same part number for both the 93-97s and the 98-02s. When I ordered the Spohn SFCs for my car from Speed Engineering, the box came in the mail and it said 98-02 part number 504. I called up about it and they said the same part number is used for all of the 93-02 cars.
Old Jul 4, 2006 | 12:48 PM
Spohn may have modifed the front mount design for the 98-02 SFC's so they will fit all years. He uses my car for a lot of his stuff, and I know I sent him detailed photos of the fuel line routing so he could adapt them to the 93-97 cars. Although now he has his own 4th Gen to beat on
HOFFICER
Apr 6, 2020 10:36 AM
LimitedEd1LE
May 18, 2015 01:24 PM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
