gouged drive shafts
Old Nov 10, 2002 | 07:54 AM
radarb8's Avatar
Question gouged drive shafts
I just got a aluminim drive shaft and it has a got a gouge about 1/64" deep and about 3/4' long and about a 1/4" from the weld on the pinion end of the shaft .Is this drive shaft safe to use on a basicly stock 1995 Z28 ?
Old Nov 10, 2002 | 08:28 AM
OldSStroker's Avatar
Maybe.
It's small (3/4 inch long?), and near the end. I'd be concerned about the sharpness of the gouge: sharp marks are stress risers and can become cracks after many, many revolutions. This is especially so for aluminum.
You might try smoothing out the gouge with a Dremel tool or file and sandpaper. Try for a smooth radius at the bottom, top and ends of the gouge so it looks more like a dent.
As you work it, look carefully to see if there is a crack at the bottom of it. You need to get to the bottom of the crack and file it out.
If you know of a certified aircraft welder in your area, he/she could repair the gouge. Your filing would probably be good preparation.
My $.02
Old Nov 10, 2002 | 01:50 PM
LJ93Z28GM's Avatar
On a stock Z you will be fine. If it is a 6 speed car and you are on a slick or somesort of tire i might be concerned.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
