Out of adjustment on Camber
Old Jun 25, 2006 | 05:26 PM
69gto96z's Avatar
I lowered my car and took it in to have it re-aligned and they said my camber is out of adjustment and it is still a degree off. Is there anything I can buy to correct this? Like a camber kit or anything?
Old Jun 25, 2006 | 09:30 PM
Re: Out of adjustment on Camber
I've taken the front end down almost 2" and they were still able to align it.
But what specs are you trying to align it to? You don't want to use stock alignment specs on a lowered car (actually, the stock specs aren't all that great for a stock height car). I ran -1deg camber, +4deg caster, 0.10 toe. There are simlar specs in the 4th Gen FAQ for lowered cars:
http://www.f-body.org/faq/4/4_5.htm
Old Jun 25, 2006 | 09:33 PM
Ricardo's Avatar
You can use a set of adjustable upper A arms from BMR or some other supplier.
One degree off is not that bad at all. I suppose you are talking negative camber.
You could also remove the lower A Arm completely and make the slot longer on the K Member to gain a little more adjustment
RG
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
