Scanmaster O2 voltages dropping.....
Old Jun 24, 2006 | 08:57 PM
wrd1972's Avatar
I have noticed that my Scanmaster is showing me the O2 voltages are dropping. At WOT 1/4 mile conditions I used to be around 880mv.
I am now seeing 830-850mv. Is this indicative of something bad.
The performance issue I have is a slight 5500-5700 stumble.
Could the two be related?
Old Jun 25, 2006 | 01:40 PM
Re: Scanmaster O2 voltages dropping.....
Could be the A/F ratio is leaner that it used to be. Or it could mean the temperature at which the O2 sensors are operating has changed. That's the problem with trying to tune using stock narrow-band sensors. At 13:1 they are more sensitive to operating temperature than they are to real changes in the A/F ratio.
Old Jun 25, 2006 | 01:43 PM
Honda Hunter's Avatar
What is each one reading? I noticed simuler changes when I went to race fuel or when the weather changed. Also when my left went bad that was the first thing I noticed was a voltage drop.
Old Jun 28, 2006 | 08:50 PM
wrd1972's Avatar
At the end of a 1/4 mile run they are both in the 840-850 range. They used to be around 880-900.
Does this mean that it has started getting lean or rich?
Old Jun 28, 2006 | 09:23 PM
Lean.
Old Jun 29, 2006 | 11:03 AM
Or it means the operating temperature of the sensors changed. They are NOT accurate at WOT.
marlar98
Sep 12, 2018 07:18 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
Aug 7, 2015 01:26 PM
