Overheating issue
Old Jun 16, 2006 | 02:44 PM
GrdLockV6's Avatar
Overheating issue
My car's recently started overheating occasionally. It only does it in the hot sun while I'm stopped in traffic. The temp will start to rise, and my low coolant light will come on. I've checked, and the radiator is topped off with fluid. The first time it got almost in the red, and I turned the heater on and the temp dropped down quick. It's been a week without overheating, and now it did it again today in traffic, luckily I got out of it and got back up to speed, and it dropped down to normal.
I tried to duplicate the problem once I got home... parked the car, left it running, as soon as the temp would get slightly above 210, the fan would kick on and it would go down... I couldn't get it to overheat again.
What could be causing these random overheatings? Is the fan for some reason sometimes not kicking on when it should?
Old Jun 17, 2006 | 03:26 PM
JDBlaze85's Avatar
Re: Overheating issue
sounds like the fan relay or the fan motor not kicking occasionally. or even the coolant temperature sensor could be going bad.
change the fan relays out first. that doesnt cost much and takes maybe 2 seconds to change out.
are you overheating with the a/c on? because the fans kick on with the compressor on automatically regardless of ANY coolant sensor reading.
investigate the fans.
Old Mar 1, 2010 | 02:01 AM
geo1400's Avatar
Sorry to bring this back from the grave, post #2 completely applies to me and i'm wondering if there are any other opinions on the matter.
My car starts to overheat when I turn the A/C off, put the A/C on and i'm sure I can hear the fans kicking in and the temp will stabilize. I also get that coolant warning light coming on but if anything, my coolant level is too high, would that also cause the light to come on once the system pressurises?
I might start with the coolant level sensor and relays to see if that solves anything.
Any opinions appreciated.
Old Mar 1, 2010 | 06:48 AM
AL SS590 M6's Avatar
Coolant level sensor only indicates low coolant level. If it comes on only when the car overheats then maybe you have a head gasket issue?
Check your fan motors with a hot wire and check your fan relays.
warmeck
Apr 16, 2015 05:50 PM
sseeya
Apr 9, 2015 06:38 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Alex Barnes
Jan 24, 2015 10:21 PM
yosshimura
Classic Engine Tech
Aug 19, 2002 09:22 PM
