Comp lifters
Old Jun 15, 2006 | 01:21 AM
GhostZ28's Avatar
Comp lifters
Is there any advantage to #875 Comp. lifters? for 120 dollars? I've got the chance at a good deal, so if its worth it for extra reliability, I might just install them with my H/C in a couple weeks.
Old Jun 15, 2006 | 10:41 AM
Greed4Speed's Avatar
Re: Comp lifters
Stock is fine
Old Jun 15, 2006 | 04:15 PM
GhostZ28's Avatar
Re: Comp lifters
So its really not worth an extra hundred bucks at all?
Old Jun 15, 2006 | 06:43 PM
93yellowta's Avatar
Re: Comp lifters
Don't do it,, look at the sticky at the top of the LT1 forum... they fail, I just had my heads and cam put in last month,,and new comp 875 lifters, I just pulled the intake today because car has run like crap since I had it done, four of them failed...the clips cam completly off.. now there somewhere in the oil pan...
their trash... oem will work fine...or summit has there brand which I heard are made by crane for 104.00 for the set..
Old Jun 15, 2006 | 09:03 PM
GhostZ28's Avatar
Re: Comp lifters
Does anyone second the Summit lifters or stay with the ones in the car? The reason I'm asking so much is its just hard to believe that oem equipment can be that much more reliable.
Old Jun 16, 2006 | 10:24 AM
Re: Comp lifters
He's got an LTI...I've never seen LS1 Summit lifters, but I'm not in the market for them either.
Do a search on ls1tech for the Comp lifters.
Old Jun 16, 2006 | 11:42 AM
GhostZ28's Avatar
Re: Comp lifters
I'm pretty sure they're all the same lifters, anyway, thanks for the help
Old Jun 16, 2006 | 12:40 PM
Kraest's Avatar
Retired
Re: Comp lifters
I'd get the Melling stock-style lifters for $160.
Mike
Old Jun 16, 2006 | 01:39 PM
GhostZ28's Avatar
Re: Comp lifters
its not that i necissarily NEED to replace them, its kind of like why I replaced ny rockers with harland sharps, If it will be just a bit more reliable and let me rev a little higher safely, then it'll be worth it.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
