AIR system
Old Jun 11, 2006 | 07:52 PM
Zachz28's Avatar
AIR system
OK i am an LT1 guy but i need to learn about your fancy TPI systems . My first question is on a 1989 Formy the air injection system. On this system the AIR is injected into manifolds, now on an LT1 the AIR is also injected into the manifolds. And on this system it only runs the first 2 min of start up to heat up the cats. This is why on an LT1 AIR can be removed and have to effect on the emissions sniff test. Now since the system on the formy is the same (AIR injected into the manifold) i want to know when if this system only runs during the first 2 min also. I would think it would have to because if it was on all the time it would screw up the O2 sensor readings right?
Old Jun 11, 2006 | 08:27 PM
xpndbl3's Avatar
Re: AIR system
only runs at certain times and is not necessary for emissions. everyone around me passes no problem with no air and just cats on thirdgens.
Old Jun 16, 2006 | 01:12 PM
HOZZ4's Avatar
Re: AIR system
The TPI A.I.R. system runs on the exhaust manifolds for a few minutes after a cold start. It then switches to the catalytic converter (only) after that. It will bypass both the cat and the manfolds under the following conditions:
rich operation (i.e. sustained full throttle)
decelleration (high vacuum, closed throttle)
high rpm light throttle
any time the car is in limp or bypass mode (I believe...)
Old Jun 17, 2006 | 06:08 PM
BrandonKeith's Avatar
Re: AIR system
Will pulling it off of a TBI 305 help out in the power department any? Or would it just be easier to just leave it installed?
Old Jun 18, 2006 | 11:47 AM
respectirocz's Avatar
Re: AIR system
disconnecting the belt saves horsepower
pulling it off also saves weight
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 1, 2016 05:37 PM
novaiiman
May 15, 2016 11:36 AM
95chwagon
Jan 13, 2015 09:19 PM
