Carb Question...
Old Jun 10, 2006 | 07:05 PM
rwjohnson06's Avatar
Carb Question...
When I look at my carb and open the throttle wide open the secondaries dont open up. How do I fix this problem? Any help is appreciated. Thanx in advance.
Old Jun 11, 2006 | 01:31 AM
angel71rs's Avatar
Re: Carb Question...
Depending on the carb, that might be normal. What type of carb, if Holley, what is the list #?
Old Jun 11, 2006 | 02:42 AM
its a Rochester 650.
Old Jun 11, 2006 | 03:58 AM
Angelis83LT's Avatar
Those are Vacuum secondries.. IIRC those are only supposed to open once the vacuum reaches a certain point and the car is under load... otherwise they should not open...
Old Jun 11, 2006 | 09:50 PM
firebird69racer's Avatar
Is it an older Rochester or is it a Q-Jet
If it's a Q-Jet then it depends on witch throttle blades your looking at. The Q-Jet have two sets of secondary blades. there is one set on the bottom with the primary ones which do open as you open the throttle all the way, the top set are the ones that open with vac.
On the bottom set there is a little lever that keeps them from opening unless the choke is fully open.
To check to see if the bottom ones open, hold the choke open all the way, hold the top secondries open then look down through the carb and see if the bottom ones open as you move the throttle open
Wade
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
dylan1303
Aug 12, 2015 02:00 AM
bose
Jan 30, 2015 02:36 PM
