A/C + Cruise control problems HELP!
Old Jun 9, 2006 | 03:47 PM
LT1Formulation's Avatar
I seriously need help with my A/C and cruise. Neither of them work. I've been working on the A/C issue and this is what I have figured out so far:
- Low side pressure switch is working.
- No power to A/C compressor
- A/C / Cruise control fuse has power at the fuse box
- A/C Compressor relay is not energizing.
- Using jumper wires to ground terminals for relay in fuse box causes A/C compressor to turn on.
- Turning on switch for A/C has no effect other than turning the blower motor on, usually when set to max cool, the blower motor runs at a higher RPM. Switching from max to A/C doesn't have any effect.
Where do I look next? Is this a switch malfunction or something else? Also, the BCM has no codes.
Old Jun 9, 2006 | 04:09 PM
jsetzer's Avatar
Re: A/C + Cruise control problems HELP!
They share the same fuse. The wire going down to the compressor on mine was burned underneath the altenator and gave me hell one summer.
Prob doesn't help you much, but thats all of my insight.
Old Jun 9, 2006 | 05:48 PM
I knew that they shared the same fuse... I checked the wiring and it's fine - if I bypass the relay the compressor comes on, so it's not a wiring issue.
Old Jun 9, 2006 | 10:55 PM
Mustang Crusher's Avatar
Unless you live somewhere hot and like the A/C, get rid of it all together. It steals HP from you engine when you run it. Not to mention, you could use that space for better things, like performance goodies. Just my opion.
edman
Mar 13, 2015 09:39 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
alphaauto
Feb 5, 2015 05:25 PM
jayblev95
Jan 6, 2015 11:52 AM
slothgrant
Aug 22, 2002 03:01 PM
