My setup th350 or th400
Old May 28, 2006 | 01:23 PM
camaroKid223's Avatar
I am running the motor in the sig below on a 175 shot and just installed a 9 inch with a 3.70 gear. Right now I have a TCI built 700R with manual valve body but im thinking I may want to step up to something with a trans brake. I plan to add heads later on, should I stick with what I have or move up to a th350 or th400?
Old May 30, 2006 | 09:10 AM
Re: My setup th350 or th400
no one has any ideas?
Old Jun 1, 2006 | 12:34 AM
revtime's Avatar
It depends alot on what you want to do with the car.
Are you going to be driving it alot? cruises, car shows, alot of travel?
If so then I would stay with the 700R4.
If your going to be doing more racing then I would get a built TH400 and never have to worry about busting the tranny ever again.
I have a Rossler TH400 in my 94Z and I love it, but I travel at about 60 MPH on the hiway and there is no way I would make a long trip in the car.
Strictly car cruises close to home and a little late nite action. But thats what I built it for.
I killed 2 60Es and I was looking at spending 2200 to 2800 for a professional build and I picked up the TH400, stall, Dennys DS and a big cooler for around 1800.
Worked out great for me but I don,t mind the limited drivability.
Old Jun 2, 2006 | 12:12 PM
the car used to make a couple 2 hour trips to the beach a year. Now its more of a car I take out a couple times a month to get street passes off, I do have a 40 min drive to the track though.
Old Jun 3, 2006 | 12:32 AM
revtime's Avatar
The 40 minute drive to the track won,t be bad, as long as you can afford the gas. I can actually drive my car anywhere, its just that you won,t want to.
Old Jun 3, 2006 | 09:44 AM
will a th350 stand up to a t-brake?
Old Jun 4, 2006 | 01:15 AM
revtime's Avatar
If properly built yes it will.
I have a Rossler TH400 in my car and I highly reccomend you contact him and have him build your TH350.
You won,t be disappointed.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
detroitmuscle
Jul 31, 2015 04:21 AM
