O2 sensor?
Old May 20, 2006 | 09:45 PM
95LT1conv's Avatar
O2 sensor?
for the 3rd time tonight my SES light came on whiloe at low rpm in 6th gear. would this be a sighn of an o2 sensor going bad? the light goes off if I shut it down for a minute or so and then start it back up.
Old May 21, 2006 | 02:11 AM
wdtiger's Avatar
Re: O2 sensor?
You might want to get it scanned to see what code it's throwing.
Old May 21, 2006 | 03:20 AM
fredmr39's Avatar
Re: O2 sensor?
Same thing happened to me after header install - turned out, it was my EGR hookup on the headers. The connection was fine though, flush...sealed with a sealant as well, but just thre code for no reason. I can't remember now if adding the RTV solved the problem or if I just had the EGR code programmed out. Either way, it wasn't really a problem with the EGR...just was throwing the code. Get it scanned definitely - my guess is EGR flow - based on personal experience only.
Old May 21, 2006 | 11:00 AM
95LT1conv's Avatar
Re: O2 sensor?
thanks guys
Old May 21, 2006 | 06:33 PM
fredmr39's Avatar
Re: O2 sensor?
let us know what the code ended up being if ya scan it...just curious
Old May 21, 2006 | 11:27 PM
StephenDeli22's Avatar
Re: O2 sensor?
I had that same situation when it threw a code and it was EGR Failure... I could turn the car off and then restart it and the code would go off. So Im not worrying about it and eventually going to get it tuned out of my PCM.
Old May 22, 2006 | 12:36 AM
Lower's Avatar
Re: O2 sensor?
Same here. Replaced EGR, then ended up programming it out a year later.
Old May 24, 2006 | 06:43 PM
Compstall's Avatar
Re: O2 sensor?
Drop on by my place and I'll get it scanned for ya.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
