torque wrench question- using extension
Old May 19, 2006 | 11:09 AM
dbusch22's Avatar
doing head gasket job, and was wondering if using a reducer and a 3" or 6" extension is going to change the actual torque of the wrench, compared to the actual reading.
I'm using a clicker type
I have read on the web so far, that using an adapter or extension (to reach the bolts on the bottom of the head for example) does not affect the wrench. I'm looking for second opinions.
Old May 19, 2006 | 11:24 AM
Z28SORR's Avatar
Re: torque wrench question- using extension
Depends on your definition of accuracy! If you are using a short 3" to 6", 1/2" drive extension, it's not going to make any appreciable difference. This is easy enough to check, just torque 4 bolts with the extention and 4 without. When go back and recheck. Obviously if you start going to longer thinner extensions, like a 3/8" drive, that 18" long your probably going to have some loss of torque at higher reading.
Old May 19, 2006 | 01:40 PM
It will not affect torque. Draw a free-body diagram, and you will see that although a longer/thinner extension might deflect in torsion, the torque applied to the bolt will be identical to the torque applied to the extension by the torque wrench. Just make sure you keep the axis of the extension in line with the axis of the bolt.
Old May 19, 2006 | 06:58 PM
95LT1conv's Avatar
the only way torque will be affected is if you extend the handle of the wrench
Old May 19, 2006 | 07:49 PM
wdtiger's Avatar
I don't see how that's possible. You'd still be applying the same amount of torque to the bolt. A longer handle would just give you more leverage to generate that torque and hence it will be easier to turn.
Old May 19, 2006 | 10:31 PM
Dave89IROC's Avatar
what? extending the handle? if a device is placed between the head if the wrench and the bolt, you need to do math to find the correct torque to set the wrench to to get the desired torque at the bolt
however, just using a normal length extension, no, you will not loose any
Old May 20, 2006 | 06:35 PM
fredmr39's Avatar
ha - good point
Old May 20, 2006 | 11:19 PM
ZeeVert's Avatar
Originally Posted by dbusch22
doing head gasket job, and was wondering if using a reducer and a 3" or 6" extension is going to change the actual torque of the wrench, compared to the actual reading....
You'll be fine with or without the extenstions. Don't worry about it.
This thread is drifting to a fine discussion on the short comings of the traditional torque wrench and it's applications. Personally I prefer a daily calibrated DC nutrunner with speed, torque, and angle control.
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
