weird noise, any ideas?
Old Nov 7, 2002 | 08:53 PM
12NV's Avatar
well first i would like to say hello to everyone this is my first thread. alright now to the problem. i have a '00 TA and when i make left turns ( like curves in the road not at stop signs) my right rear wheel makes a rythmic clunking noise. it sort of sounds like the lug nuts are loose but thats not the case, and it doesnt do it unless my foot is off the gas. also if my car is parked i can grab the rim and push and pull on it really quick it sort of makes the same sound. now i have a few ideas of what it could be but i wanted hear other ideas. thanks in advance for any help.
Old Nov 8, 2002 | 12:47 PM
ZZed's Avatar
Welcome to the forum. If I had to guess, I'd start with the bearing.
Old Nov 8, 2002 | 01:31 PM
mook99TA's Avatar
I am haveing that same problem didn't think of the lug nuts till I read your thread. I checked them and they were tight one was loose so I went to tighten it and the bolt was striped out. Not the threads for the lugs but the other end not sure of what it is called. Maybe check those. That might be the problem. My rim makes the same noise when slowing down and turning.
Old Nov 9, 2002 | 10:14 AM
12NV's Avatar
Hey thanks ZZed, i'll look into that. Hey Mook, if you find anything out let me know please, thanks.
Old Nov 11, 2002 | 09:12 PM
mook99TA's Avatar
yes I fixed it got a new bolt put on and the noise stopped....
Old Nov 12, 2002 | 04:05 AM
LuS1fer's Avatar
This is just a guess but I'm told that the handbrake on later cars is a drum brake set-up inside the rotor so it might be something to do with that if it's not the above.
Zuvell
May 15, 2015 08:18 PM
reww86
Apr 27, 2015 05:17 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
