your thoughts on how to run my Fuel Line and Blow-down tube??
Old May 6, 2006 | 02:18 PM
91MIGHTYMOUSE358's Avatar
I have bought a new NX Hitman kit. What is the best way to run the fuel line, such as splice in. I am running a 2 port regulator, so then can I just use the second port to tap into, would that be best, sure would be easiest. And I hear that I need to run a blow-down tube, I already have a hole in the floor where I can run it, but what exactly is a blow-down tube, how does it mount to the bottle, and where can I get one at??
Old May 7, 2006 | 04:25 PM
Re: your thoughts on how to run my Fuel Line and Blow-down tube??
Your bottle needs to have a safety relief fitting with an -8AN connection on it. You either get a rigid "blowdown tube" from your manufacturer, and route it through a hole in the floor, or you get an -8AN "bulkhead" fitting to put in the hole in the floor, and run an -8AN SS hose from the pressure relief fitting to the bulkhead fitting. Many bottles do not come with the -8AN fitting, and you need to buy a fitting and remove the old fitting/diffuser and replace it with the correct fitting.
What does your fuel system look like? If its a dead-ended system you can come off the regulator. If its a recirculated system with the regulator on the return line, it isn't going to work.
Old May 12, 2006 | 07:01 AM
Thanks for the input. I am running a Holley Black pump to a 2 port holley reg. closed ended to a 825 Demon carb. Where can I get the fittings you speak of ??? Only other time I ran a NOS kit was in my CHevelle, and it was in the trunk, so no blow-down was needed. Thanks for the help.
Old May 12, 2006 | 10:06 AM
You get the -8AN pressure relief fitting from the manufacturer of your bottle/valve. Example:
http://www.holley.com/16166NOS.asp
You can get an -8AN bulkhed fitting from most fitting sources, like Aeroquip. The -8AN hose can be made from parts readily available from Summit or JEG's, or can be ordered custom made from sources including eBay.
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
pologreen97z
Dec 2, 2014 10:42 AM
squarehead
Nov 21, 2014 08:02 PM
