Possible brake upgrade?
Old May 5, 2006 | 03:52 PM
hot white z's Avatar
If anyone has seen the new baer monoblock calipers, please chime in on this thread. I know a lot of people on here swear by the c5 brake upgrade, so I want to know if the "mono-block" style caliper is better than the c5 caliper. I did a search on ebay for "monoblock brake" and came up with one match- Porsche 986 rear calipers. I would just like to know if it would be a worthwhile endeavor to put these on instead of the ls1 calipers. I'll probably never spring for a c5 conversion or the baer 6-piston setup, just too much money involved.
Right now I'm still just kicking around the idea, so any input is good input.
Old May 7, 2006 | 03:17 PM
CALL911's Avatar
Re: Possible brake upgrade?
The cheapest brake upgrade is probably to the Willwood 6 piston calipers (under $1500). I am personally not sold on their quality myself. The Baer Claw 2 piston (what I currently have on my Z) is pretty much the same as the Z06 upgrade, which is superior IMO to the LS1 brakes. You can get the Baer claw for around $900. If you want to go crazy (which some day I plan on doing) and if you have the wheel clearence, you can go with some Brembo 6 piston, or some Baer 6 piston calipers. Whatever you do, make sure you get good pads and some decent rotors to back up the stopping power, otherwise you are wasting your money.
Old May 9, 2006 | 03:36 PM
I just wanted to know if the porsche 986 calipers would work better than stock ls1 calipers (rear). I'm never spending $1,000 on brakes, period.
Old May 10, 2006 | 04:22 AM
RE AND CHERYL's Avatar
Are you looking to improve your front brakes or rear??
Biggest limiting factor on the rear LS1 brakes is the small brake pad size. And even if you wanted to mount calipers that would hold larger pads, the rear of the rotor has half the swept area of the front because of the parking brake.
Re'
Old May 10, 2006 | 09:56 AM
CALL911's Avatar
The only way you will be able to tell for sure, would be to find someone who has personally felt the stopping power of the porsche 986 brakes on their F-body vs. the LS1 calipers. I have been searching for someone who has felt the difference between the Baer 2 piston vs the Willwood 6 piston, and I have found no one that has been able to say they have felt both to give an accurate judgement between the two. Of coarse if you talk to either of the companies, they both claim they are superior to the other. Good luck with your search to find the difference. If you do find out, please post the results. Many including myself would be interested in the findings.
Old May 10, 2006 | 02:31 PM
Front and rear. Apparently most of the new Porsches come with monoblock calipers all the way around and agressive stability control systems, meaning you'd either have to adapt their wheel speed sensors to be read by a gm computer (tough), or eliminate the sensors altogether (not so tough). If I went through with it, I would of course try to retain my traction control features. I wonder how much of a pita that would be?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
